LETHAL
From the D but in the NC
- Sep 26, 2015
- Asheville, NC
- Kevin
- 2018 GT A10
- Vehicle Showcase
- 1
Slicks mounted on mentioned, inner barrel is rubbing on top or spines of the caliper. Got a 5mm spacer (biggest avail while trying to use OEM length lugs) and it seems like they are still maybe rubbing. I can fit a feeler gauge in between the wheel and the caliper but it seems it may still be adding to the groove left from test fitting without the spacer.
Is this futile with this offset on non PP rear calipers?
The wheels are Cobra R reps from OE Wheel.
Also
What is the min lug thread length (turns) we need to be safe on these cars when using spacers?
Thank you
Also
Thank you
