trippleyelo
- Sep 16, 2017
- vancouver wa
- ford f250 turbo diesel and 2016 mustang svo
Well here we go..:cheers:
A week or so ago, I bought a turbo blanket ($34), thinking that I’d use it instead of having to buy an aftermarket heat shield when I install my CNT downpipe. *I did not want to have to modify the stock heat shield (cutting is involved, which would make the heat shield less effective).
So, I’ve been doing a lot of research, trying to determine if there are any real consequences in using a turbo blanket. *The premise of using a turbo blanket is to keep the radiant heat of the turbo inside the hot side of the turbocharger, which would make the heat stream more effective. *A possible consequence would be that the resulting heat would put the heat level outside the normal heat range of the hot side of the turbocharger, which could cause premature failure of the turbocharger. *Another possible consequence would be that the additional heat could cause an engine that was recently stopped to coke any oil that is in the cooling system on the hot side of the turbocharger (this could be debunked due to the fact that modern turbochargers usually are cooled by both oil and water, such is the stock turbo we have in our ecostang wether it be after market like the vargas t2 turbo I am running studies have shown us it will not reduce life of turbo
My finding is that there is no solid evidence that a turbo blanket will kill your turbocharger. *Turbochargers are built to take very large measurements of heat, so adding a heat blanket should not overburden the turbocharger. *Heat also makes the turbocharging system more efficient (the more heat, the better the turbo reacts to the demand for boost).
The main reason I want to use a heat blanket is so that my IC won’t be heat-soaked, since it is below the turbocharger (it is side-mounted). *A heat-soaked IC would more than likely cause a pull in timing during the hot months of summer or in stop-go traffic, or even at local track events.
There’s a crap-ton of information regarding this topic and I can’t seem to find any solid consequence for using a turbo blanket, so I’m probably going to install my mew turbo blanket. I’m also going to buy a top-tier heat shield, and I’ve evaluated a couple here.
Also, note that I’m well aware that there are cheaper variants of this style of turbo blanket. In doing my research, I also found that Perrin has allowed PTP the right to sell what is essentially a Perrin design (when I find that URL again, I’ll link it here). *As well, there are apparently new versions of these blankets. *They’re essentially made from ground lava rock, which allows these variants to retain heat more efficiently:clap2:
http://www.mustang6g.com/forums/picture.php?albumid=1930&pictureid=11177
this is my set up< and one roll should take of hot and cold side charge pipes & exhaust down pipe
https://i.ebayimg.com/thumbs/images/g/OmsAAOSwfVpYnU5S/s-l225.jpg
T3 Titanium Turbo Heat Shield Blanket Cover + 2" 50FT Exhaust Header Wrap Tape
Brand New
$34.99
https://i.ebayimg.com/thumbs/images/g/1TYAAOSwux5YQeU4/s-l225.jpg
HVAC Metal Repair Aluminum Foil Tape, 1.88" x 10 Yards ~ New ~ Free Shipping
Brand New
$8.99\
Cobb v3
Brisk rr14ys (briskracing.com)
Vargas stage 2 ( high flow ported head and studs)e40 tune with torco ,and not tuned by tune + for reasons
MMR ( cai)
Mishimoto catch can
AEM ( charge pipes)with two factory 1/8 nozzle adaptors taped in the cold side charge pipe
AEM ( snow kit with two nozzles)
Steel works down pipe ( high flow cat.)
2.50 double tube with dbx mufflers res delete all wrapped .
Universal (t 3 turbo blanket)
Turbo smart waste gate (17 pound spring set)
Bomba blow off and GfB DV + stacked up
INJINE INTERCOOLER (22X6X6) BAD TO BONE KEEPS ME COOL
Ford performance strut tower and k brace.
Lowering springs (BMR handling set)
IRS BRACKETS
Steeda G track K BRACE
SWAY BARS
DRAG LINKS
CARBON FIBER DRIVE line
All steeda above sure I forgot something but short list sexy in yellow.
550whp and 430 torque this how I keep her cool ..any questions let me know ..
Brand New
$34.99
Brand New
$8.99\
Cobb v3
MMR ( cai)
Mishimoto catch can
IRS BRACKETS
SWAY BARS
DRAG LINKS
