Darko66
Please read the attached PDF instruction sheet for complete details. Note, however, that the instructions are still a work in progress,. I will try to refine them along the way.
To order, visit www.darko66.com
I’ve created a simple add on attachment that improves the performance of the seat back cooler for Mustangs equipped with climate controlled seats. As shipped, the original seat blower unit cannot intake sufficient cool air to operate properly. The seat either didn’t cool at all or, in some instances, actually heated the seat. Ford did attempt a solution and issued a TSB to replace the blower with a modified unit. Unfortunately their solution appears to have fallen short.
The attachment allows you to attach hoses that you can run under the seat and past the seat cushion’s blower unit to reach cool, clean air at the front of the seat. Best mix of results can be achieved by splitting your A/C between the panel and floor vents. Maximum seat cooling can be achieved by directing the A/C to the floor only.
For the hoses, I currently recommend 3/4” ID pond tubing that can be purchased from hardware stores or online vendors for $15-20 for 20 feet. Each seat requires three 36” pieces of tubing.
UPDATE: The original attachment will only work on the original blower units that shipped on all 2015 and most 2016 models (some late production 2016 models shipped with the modified unit). I've created a new attachment for Ford's updated blower unit (see age 5 of thread for info). So, if you had the TSB performed by your dealer or if your vehicle was shipped with the modified unit, please purchase the "TSB "Sock" Version". You can tell if you have the modified unit by looking under the rear side of the seat (see under seat image below). If there is a white intake sock protruding from where the seat flap closes, you have the newer blower model.
I’d like to thank all of the commenters on the Mustang 6G forum who contributed to the discussion, especially forum member Droid_Junky whose early investigative work was instrumental in the final product. For complete details on the long journey many of us have traveled, visit the Mustang 6G forum “cooled seats not cooling” discussion – http://www.mustang6g.com/forums/showthread.php?t=23384
Additional thanks to forum member zuki_dan for some additional installation tips and for the photo below of the installed attachment.
