Can you share pics of your fore fuel system installed?
doodguy
Ruskin, FL
2015 Roush Stage 1 Supercharged Mustang GT
Specifically I'm looking for where you mounted your fuel pressure gauge, as well as where you mounted your fuel filter keeping it accessible. Also trying to see where agood place to mount the power distribution panel which turns on the 2nd and 3rd pump under boost. How often do you have to replace the fuel filter anyways?
Thanks!
beefcake
Bethel
2018 Ford Mustang
we put the filter under the little brown panel on the drivers side where we run the lines.
the f/p gauge we put on the regulator. set base at 55psi typically
