New clutch install(Rxt Mcleod) what is needed?
v8ter
Typing...
EL PASO , TX
MUSTANG GT 2015 50TH
I recently bought a Rxt clutch, but Im gona buy the flywheel as well,so what else am I gona need or whats suggested to change while Im in there?
evo8904
I'm a member???
Tampa
Luther
2017 Ram 4x4
I would do a steeda clutch line at the same time too
v8ter
v8ter
Typing...
EL PASO , TX
What does it do?
gzstang
Who's stang? It's gzstang
Lincoln Nebraska
2015 Mustang GT w/performance pack
What does it do?
The factory line will expand under pressure and fail over time. You want all the pressure to be used to release the clutch, not expanding lines. So the stainless will consistently keep the pressure going to the clutch were you want it.
v8ter
v8ter
Typing...
EL PASO , TX
That explains it well, thanks
Do I need any different bolts ,seals or something yet to do the install ?
evo8904
I'm a member???
Tampa
Luther
2017 Ram 4x4
Nah, the kit will have everything you need
v8ter
v8ter
Typing...
EL PASO , TX
So I see there are 2 diferent lines upgrades available, Mcleod and steeda, is there a difference between them?
v8ter
v8ter
Typing...
EL PASO , TX
After clutch install do I need to do the crank relearn?
pro 5.0
Canada
2019 Mustang GT
ARP flywheel bolts wouldn't hurt either and correct me if I'm wrong but you shouldn't need to do a crank re learn if you leave the reluctor wheel in it's same position.
v8ter
v8ter
Typing...
EL PASO , TX
zuki_dan
North Carolina
15 Mustang GT Premium M6 TY
The factory flywheel bolts are supposed to be torque to yield. I replaced mine with the ARP bolts.
I didn't replace the slave/TOB, only 14K on my car when I installed my RST and steel flywheel. I do all my own work so if the TOB goes bad I will change it. I also used the Steeda clutch line. It is a pain to bleed if you let all the fluid drain out also. The first couple hundred pumps I did with my hand.
whatsup62
Jupiter
I did not do TOB/slave...but its a good idea. I also did Ford racing stainless line. I had to do a crank relearn.
v8ter
v8ter
Typing...
EL PASO , TX
Can somone explain what the slave/tob is?
