GT350 McLeod RXT Clutch Install and Flywheel Bolt Warning
ben@fatfab
Gold Sponsor
Indianapolis, IN
2011 Mustang GT Turbo
We recently installed the new McLeod RXT for the GT350 in Tony's twin turbo car and we wanted to share some data, pics and a warning about the flywheel bolts that you use.
This will be pic heavy and I'm going to attempt to do some math here so forgive me if its hard to follow along! I'll be happy to answer any questions.
Here is the RXT next to the Stock clutch and the 3 flywheel bolts we are going to talk about.
McLeod RXT clutch assembly on the scales as well as the flywheel by itself.
Stock clutch on the scales as well as the flywheel assembly by itself.
Here are the three flywheel bolts from Left to Right is the stock OEM Ford bolt, longest ARP bolt we could find and the bolt we ended up using.
The issue we ran into is that the stock bolt does not provide what we consider adequate thread engagement. The crankshaft has a 0.13" chamfer before threads begin as seen here.
The crank trigger wheel is 0.12" thick as seen here.
If I did my math right that means you have 1/4" or .25" of space before the threads begin to engage into the crank.
Here is how much the stock bolt (what McLeod told us to use) sticks through the flywheel.
So doing math here again we take 0.425" minus 0.25" and we get 0.175" of thread engagement! Thats roughly 3-4 threads, not nearly enough in our opinion. The ARP bolt was slightly worse at 0.410" without the washer.
This is how much engagement Ford has with the stock bolt and stock flywheel. So thats 0.70" of thread engagement from the factory compared to the 0.175" we got with the McLeod flywheel!
With the amount of vibration with the flat plane crank and problems experienced with clutches in these cars we believe this needs addressed. Our bolt solution gives you almost as much engagement as stock at 0.65" and we include it with every GT350 McLeod clutch we sell free of charge!
Please let me know if you have any questions. Enjoy your weekend guys!
-Ben
Zitrosounds
Madison, AL
Harold
With the amount of vibration with the flat plane crank and problems experienced with clutch in these cars we believe this needs addressed. Our bolt solution gives you almost as much engagement as stock at 0.65" and we include it with every GT350 McLeod clutch we sell free of charge!
-Ben[/quote]
I an aviation application 1 thread showing is acceptable. I would say that 2 or more is completely adequate. If vibrations cuase the bolts to loosen you have PROBLEMS regardless how many threads are showing.
https://www.engineersedge.com/hardware/minimum_threads_protruding_beyond_nut_13155.htm
cj428
Carl
2017 GT350R TT
looks like ARP needs to make us some longer bolts.
ben@fatfab
ben@fatfab
Gold Sponsor
Indianapolis, IN
Harold that is protrusion on the other side of the nut, so full engagement of the threads of the nut with 1 or 2 threads past that ;)
NipSC4328
Northern Oklahoma
Jim
2020 GT500 Twister Orange w\ Black OTTS
So, we're talking 1-2 threads "into" the nut vs. 1-2 threads "past" the nut?
ben@fatfab
ben@fatfab
Gold Sponsor
Indianapolis, IN
Correct, into the crank in this case but same concept.
SVT_Lewis
HPJ Performance
House Springs, MO
Lewis
03 Cobra
Do you have dimensions of the bolts you chose to use?
Is this something that is pertaining to the RXT or both RXT and the 1200 version?
ben@fatfab
ben@fatfab
Gold Sponsor
Indianapolis, IN
Thread length is 41mm. I have a pretty good amount in stock if anyone needs some I can sell a set for $75 plus shipping
This will pertain to any clutch that uses that flywheel. I assume its the same for RST, RXT, and 1200HD versions when using the McLeod flywheel.
ScottsGT
Lake Wateree, SC
Scott
2015 GT, DIB
Well that's a minor detail that will derail a weekend clutch/flywheel swap.
superman07
columbus ohio
2016 gt350
Is your option the 6337807M OR 6337807HD? Tired of waiting for Mantic to respond to my price request.
McLeod RXT Twin 1200 Clutch Kit & Flywheel Bolts
ben@fatfab
ben@fatfab
Gold Sponsor
Indianapolis, IN
Superman, McLeod is out of stock on both clutches right now.
They are quoting 10 days on the 1200 clutch.
I can get you the Mantic, which one are you looking at? The twin or the triple?
ScottsGT
Lake Wateree, SC
Scott
2015 GT, DIB
I've got to ask, I'm assuming this is the 5.2? How are the bolts for the 5.0 fitting? Is this just a 5.2 issue?
ben@fatfab
ben@fatfab
Gold Sponsor
Indianapolis, IN
Scott the 5.0 doesnt have an issue its only the 5.2 Voodoo setup.
