Wifi controlled ambient lighting.
Chameleon
Gold Sponsor
S550 INTERIOR DRESS UP
www.ebay.com
Embedded for ya. Looks great!
[ame]
Kuronos
GA
Mustang GT
Do you have a link to how you did everything? I would love to know what you bought and how you did it
ponie1992
ponie1992
Elgin, SC
2016 Ruby Red PP GT
ponie1992
ponie1992
Elgin, SC
2016 Ruby Red PP GT
This is the app that my controller uses. Some controllers use different apps, but my uses this one.
Jeremy
2016 Ruby Red PP GT
magnetticmadness
Southern California
2018 mustang gt premium OW 10spd
looks great! could you explain what you used for the cupholders? i didnt see anything for that in the links. also did you put another light right below the start button?
ponie1992
ponie1992
Elgin, SC
2016 Ruby Red PP GT
I had to make this kit work. Extended the cup holder wires so one would reach to the front of the shifter. The cup holder doesn't allow much choice for placement with the kit I used. I may eventually get a factory illuminated cup holder, but this works for now.
Jeremy
2016 Ruby Red PP GT
ponie1992
ponie1992
Elgin, SC
2016 Ruby Red PP GT
The way I have the relays wired, the lighting comes on with the parking lights or when a door is opened. There is one issue that I haven't figured out yet. After driving and shutting the car off, the lighting won't come on when the interior lights turn on, even if I open the door. I can hear the relay switch, but they don't come on. Now, if I wait until the interior lights turn off, I can then open the door and the lighting will come on. Not sure what exactly happens right after the car is shut off.
Jeremy
2016 Ruby Red PP GT
xfyre101
Sunshine State
`15 CO PP GT
so this is brighter than the factory lights right? can you change that level of brightness/dim with the app?
ponie1992
ponie1992
Elgin, SC
2016 Ruby Red PP GT
Not sure if they are brighter. Yes, you can dim them, pick a solid color, flashing colors, fading colors, etc. In the video, I had it on a slow fade. It can speed up and slow down more from where I had it.
Jeremy
2016 Ruby Red PP GT
ponie1992
ponie1992
Elgin, SC
2016 Ruby Red PP GT
Oh and I should mention, you can turn them off and on in the app and the controller will keep the last setting. If you have them set how you like it, they will return to that setting when powered back up.
Jeremy
2016 Ruby Red PP GT
ponie1992
ponie1992
Elgin, SC
2016 Ruby Red PP GT
So, I think I figured out what is causing the issue with the lights not coming on at times. It is intermittent and I believe due to the dimming on and off of the dome light. I disconnected the trigger wire for the parking light relay and still had the issue. Reconnected that and disconnected the trigger for the dome relay. Lights work perfectly except they only stay on for about 30 seconds after a door is opened. I need to find a trigger wire for the dome that isn't in the dimming circuit (if one exists). I'll run it with just the connection to the parking lights for now until I can find a solution.
Jeremy
2016 Ruby Red PP GT
lucasszy
Norcal
Lucas
2016 Magnetic GT - 6MT
Jeremy
2016 Ruby Red PP GT
THis is me guessing, but what about tapping the (i think.. purple wire) that is used for the illuminated sill plates. Passenger footwell kick panel.
Having that run a relay that should be able to continuously power multiple circuits like theses. That should provide continuous lighting along the lines of having open doors or dome lighting on... I think.
