Improving the Airaid CAI
Jeff's FRC
Lakemoor, IL
Jeff
2020 Mustang GT
First, I'd like to apologize for making yet ANOTHER cai thread, but I think a few guys would benefit from a few pics and an explanation of what I did. :thumbsup:
Imo, the Airaid has the best design with the closed box setup. I've seen countless guys complain of high IAT's with open box setups and even seen guys on this forum get cooler IAT's from making plexiglass toppers for their JLT's. I don't want to start a debate on CAI's, just wanted to give MY reason for going with the Airaid.
I'll be getting a tune, so I decided to remove the molded insert to get a bigger diameter tube making my Airaid a "tune required" intake. The pic below is what it will look like after taking a Dremel with a cutoff wheel to the end of the tube. After the Dremel, I had to take a hacksaw blade and saw into the tube through the slit I made with the Dremel to get through some of the plastic from the injection molding process.
Here is the insert removed.
Here is the tube after some sanding work. It'll be self explanatory what you need to do after you get the insert out.
To finish it off, I removed the Airaid gel logo on the tube and replaced it with a Ford gel logo that I got off eBay. I also removed the ugly aluminum trim panel that goes over the plexiglass. To remove the aluminum cover, you will need to shorten the button screws or just add 1/4" lock washers. The screws supplied by Airiad are 1/4-20x1/2". The hardware store by me didn't have any 1/4-20 hardware shorter than 1/2", so I just went the lock washer route.
BOBS550
Port St Lucie Fl
Bob
2019 Mustang GT Auto Race Red
Thanks for sharing, it came out looking GREAT! Let us know how the tuning goes the FORD sticker is perfect..:thumbsup:
BKinn
St. Charles, Missouri
Brendan
2015 Mustang GT
Looks fantastic. The Ford sticker is the icing on the cake. I always hated how cheap the Airaid looked on these. Makes it look OEM!
jrt6
Houston, TX
2015 White Ford Mustang GT Premium, 6MT
Where did you get the Ford decal from? I'd love to get one as well!
Chameleon
Gold Sponsor
S550 INTERIOR DRESS UP
www.ebay.com
Nice job, that come out great!
Evo_Rob
Mmm... Boost...
Virginia Beach
Rob
So, that little insert is what causes the necessity for a tune? I can't imagine that restricts enough for that.
Coaster
RallyNorthAmerica.com
Central Ohio
www.imprtcl.com
Brian
'15 Fastback GT Guard
You have to understand how a MAF works. It measures the airflow across the sensor, that is all it knows. The car then calculates total airflow based on the reading from the sensor and knowing the diameter of the tube the sensor is installed in.
If you inset the MAF in a 5" tube instead of the factory 4" tube there is now more air flowing through the tube at a given velocity reading from the MAF. This is why you need a tune, to change how the car calculates airflow.
So the only thing the insert in the Airaid or any other intake that uses a restrictor does is choke the tube down to the factory diameter so the MAF readings are what the factory calculations expect.
Evo_Rob
Mmm... Boost...
Virginia Beach
Rob
It just doesn't seem like that thin of a restrictor wouldn't do much. I do understand the principal of it though
D.Brown
Save the Manuels
Rhode Island
David
15' GT
Is there a whistle with this intake as well at partial throttle that's audible with the windows down?
Jeff's FRC
Lakemoor, IL
Jeff
2020 Mustang GT
I got them off eBay. They measure 3.5"X1.5"
http://m.ebay.com/itm/2-NEW-FORD-ho...o-gt-taurus-/291534284456?txnId=1228517721019
They come in a package of two.
The picture of the insert is a little deceiving. It's really thin, but it closes the diameter of the tube more than it appears because it doesn't sit flush with the ID of the tube. I didn't measure the ID of the insert, but I just measured the ID of the Airaid tube without the insert, and it looks to be about 108mm. I believe the stock diameter is 85mm so that's quite a difference in the ID of the intake tube from stock to Airaid without insert.
Not sure, and I won't have it installed till spring so hopefully someone can chime in and answer for you.
Evo_Rob
Mmm... Boost...
Virginia Beach
Rob
Right on. It's definitely deceiving to me haha.
cbrtrx
tampa fl
2016 mustang gt
Thats the first thing I did when I got my airaid, it absolutely requires the maf to be calibrated.
Old Car Guy
WV.
GT350 Tech Pack. AG Black Roof Black Stripes G3597
Ford Emblem........
I want to take this time to THANK JEFF, he has been so much help telling were to find the Ford Emblems, and I have put mine on today..... Wow it is so much better looking then the Airaid Emblem, you guys and gals will love this cheep mod........
JEFF AGAIN THANKS..... Your a good Man..... John :cheers: :thumbsup::thumbsup:
Jeff's FRC
Lakemoor, IL
Jeff
2020 Mustang GT
I wand to take this time to THANK JEFF, he has been so much help telling were to find the Ford Emblems, and I have put mine on today..... Wow it is so much better looking then the Airaid Emblem, you guys and gals will love this cheep mod........
Anytime John glad I could help ya out:thumbsup:
Nick@JDM
www.teamjdm.com
Nick
2014 Tremor
Very interesting to see this thread!
We did the same thing a few months ago. After testing with the JLT Intake and saw some gains with the larger MAF housing we modified an Airaid kit just like you did. We also added the Ford emblem and made our own tinted box cover to give it a nicer look.
We have a great tune developed for this intake combination for manual and automatic cars as well. Our car is an auto so we spent a lot of time and R&D on that tune. It is pretty kick ass.
2015 Mustang GT JDM Custom Tuning
Here are some pictures of our finished product:
