2016 Ford Shelby GT350 Mustang Chassis First Look
flaps
2019 WRX
UPDATED WITH OFFICIAL FORD PRESS RELEASE:
Ford Shelby GT350 Mustang Raises the Bar for Handling
  • Advanced suspension tuning on Shelby GT350 and Shelby GT350R includes Mustang-first MagneRide dampers
  • Two-piece brake rotors for Shelby GT350 and Shelby GT350R are the most powerful brakes ever fitted to a production Mustang – with Michelin tires and high-performance wheels engineered to match
  • Stiffened chassis – including an injection-molded carbon fiber composite grille opening reinforcement – provides a rigid base to build the most track-capable Mustang ever
The all-new Ford Shelby GT350 builds on Carroll Shelby’s original idea – transform Mustang from a great everyday car into a dominant road racer, elevating it to a new level.
Shelby GT350 raises the bar significantly over the already very capable 2015 Mustang GT performance pack, combining the best technologies and most thoroughly engineered components to create the most athletic Mustang ever built.
“When we started working on this car, we wanted to build the best possible Mustang for the places we most love to drive – challenging back roads with a variety of corners and elevation changes, and at the track on weekends,” said Raj Nair, Ford group vice president, Global Product Development. “Every change we made to this car was driven by the functional requirements of a powerful, responsive powerplant – nimble, precise handling and massive stopping power.”
Suspension tuned for maximum performance on road and track
Handling is the performance playground of Shelby GT350, and the car’s suspension is heavily revised to maximize cornering performance.
Shelby Mustang features all-new aluminum front knuckle, hub and bearing assemblies that are stiffer and lighter than the standard parts. Rigid bushings are fitted to the control arms and subframes for improved steering feedback. Heavy-duty bearings are added for increased lateral stiffness. Front and rear antiroll bars are increased in diameter for improved body control. In an example of obsession to detail, one side of the rear suspension features a new counter-wound rear spring and matching rear control arm so the left and right sides are mirror images – perfecting wheel motion.
MagneRide suspension makes first appearance for Mustang
The star of the Shelby GT350 suspension is the first-ever Ford application of continuously variable MagneRide dampers. The dampers are filled with a hydraulic fluid impregnated with iron particles. When an electric current is passed through the fluid, near-instantaneous adjustment of the suspension performance can be made. With wheel position sensors monitoring motion thousands of times per second combined with other vehicle data, changes can be made to each corner every 7 milliseconds for optimum handling performance.
Tireless calibration and tuning has resulted in an integrated driver control software which monitors wheel position, steering angle, damper temperature, signal quality, vehicle position and much more. This advanced software rides on top of the car’s drive modes and provides a degree of suspension performance never before seen in a production Mustang. This system is not just designed to make the car handle better, but to instill greater confidence in even the best driver.
Most powerful brakes ever fitted to a Production Mustang
Reducing unsprung mass is key to improving responsiveness, but a balance must be struck between taking mass out of a suspension and delivering truly capable braking performance. Shelby GT350 features the most track-credible brake system ever offered on a production Mustang, consisting of two-piece cross-drilled iron rotors with aluminum hats – the largest rotors Ford has ever put on a production Mustang. Massive 394-millimeter front rotors and 380-millimeter rear rotors are a floating-type and are pin-driven to the aluminum hats to greatly reduce heat transfer to the bearings. These rotors are clamped by six-piston fixed Brembo calipers with integrated caliper bridges at the front and four-piston units at the rear. Dedicated ducting assists in cooling the brakes front and rear for maximum performance.
“These cars can be driven by any driver on any track in the world – with virtually no fade,” remarks Brent Clark, vehicle dynamics supervisor.
Wheels and tires fit for the track
Shelby GT350 makes use of extra-stiff 19.0-inch cast aluminum-alloy wheels – 10.5 inches wide in front, 11.0 inches in the rear – clad in Michelin Pilot Super Sport tires with GT350-specific sidewall construction, tread face and compound. The custom tires are designed to deliver maximum grip on the road or for weekend track days.
Shelby GT350R raises the standard even further. It wears carbon fiber wheels, making Ford the first major automaker to introduce this innovative wheel technology. The hand-laid wheels are 19.0 inches in diameter – 11.0 inches wide at the front and 11.5 inches at the rear, each fitted with custom formulated Michelin Pilot Sport Cup 2 tires. Combined, these wheels eliminate approximately 50 pounds of unsprung weight compared to the aluminum-alloy wheels and Michelin Pilot Super Sport tires on Shelby GT350.
Stiffer chassis
The new platform is the strongest in the history of the Mustang brand, with torsional stiffness increased 28 percent over the previous model. That stiff structure ensures the suspension geometry remains consistent even under the loading caused by hard driving. Shelby GT350 takes that philosophy further – with added bracing to increase overall stiffness. A new lightweight aluminum tower brace connects the shock towers and firewall, and improves front end stiffness. When a lower hood was called for to improve aerodynamic performance, Ford Performance re-engineered the grille opening reinforcement with a carbon fiber composite structure that is 24 percent lighter than the base Mustang while maintaining the stiffness of steel. It is finished so well a beauty cover is not needed – eliminating another 1.9 pounds.
https://media.ford.com/content/ford...t350-mustang-raises-the-bar-for-handling.html
Get ready to experience the best-handling Mustang of all time. That was essentially the promise Ford Performance honcho Dave Pericak made at a little show-and-tell of the forthcoming Shelby GT350's dirty underbits, some 90 percent of which are unique to this model. Let's get straight down to the steak that goes with that sizzle, working from the chassis down to the tires:
Subtle chassis bracing and an aluminum shock-tower brace give the GT350 and GT350R a stiffer foundation for the suspension to work from. To enable a slight lowering of the front of the hood for aerodynamic reasons (the entire "front clip" is unique to the GT350), Ford Performance engineered a new grille-opening reinforcement panel with a carbon-fiber composite structure that is 24 percent lighter than that of lesser Mustangs while matching the stiffness of steel. Oh, and it looks so much nicer than the steel one that the 1.9-pound beauty cover ditched.
Nearly every suspension part is altered in some way, but completely new ones include aluminum front knuckles that replace iron ones. This saves weight, but the reason for the new parts was to "fix" geometry that wouldn't have worked with the wider track and much wider front tires (see below).
Using two diagonal links instead of a lower control arm provides a virtual steering axis, and spacing the ball joints farther apart decreases the kingpin offset, preserving the natural steering feel of the baseline GT Performance Package car. The hub and bearing assemblies are stiffened and lightened relative to the standard parts to withstand increased lateral forces. Bushings, spring rates, and roll rates are all altered, and though no hard numbers were offered, we're told the car is roughly 20 percent stiffer by most measures than the baseline.
In the rear it was discovered that because the lower spring perches rotate with the lower control arm, the left and right side springs were behaving slightly different. So they specified symmetrically wound springs — one coiling up clockwise, the other counterclockwise. Of course this required revising the shape of one control arm, which offered the opportunity for some slight shape optimization for mass-reduction purposes (they're roughly a half-pound lighter per side), which then needed to be echoed on the other side, so those parts are new.
Finally, and perhaps most important, this will be the first Mustang to utilize MagneRide magnetorheological shock absorbers, and the vehicle dynamics team leveraged the 7-millisecond damping-alteration capabilities of these wonder shocks to go lighter/less aggressive on the anti-roll bars.
It should also be noted that most of the suspension calibrations, bushing durometers, and so forth are slightly stiffer still on GT350R models, which will also likely ride slightly lower than the GT350, which also rides lower than the GT Perf Pack. The MR shocks are also unique, with the internal piston orifices smaller on the R. The ride modes offered include Tour, Sport, Track, Weather, and Drag. That last one loosens everything up a lot to encourage as much rearward weight shift as possible during a hard launch then gets ready to stiffen things up for the first-second shift, so as not to get squirrely. Track is also optimized to behave well on FIA curbing. Some modes allow further individual tailoring of steering feel and stability-control thresholds.
The six-piston front and four-piston rear fixed calipers are branded and supplied by Brembo, but they were engineered in house at Ford Performance, and they features the latest co-cast iron/aluminum technology. The internally vented and perforated iron rotors (15.5 inches in diameter up front, 15.0 in back) feature holes into which brass-coated stainless steel pins are inserted, pointing toward the center of the rotor. Then these pins are cast into an aluminum center "hat." Because the pins aren't fixed to the rotors, the iron is free to expand and contract as they heat and cool. In the rear, the "hats" also accommodate drum parking-brake mechanisms because the fixed calipers don't lend themselves to mechanical ratchet parking brakes. This brake setup is unique to the GT350 and GT350R and can't be fitted to lesser Mustangs.
Considerable computational fluid dynamics research was applied to the underbody in order to route sufficient air to these brakes. No carbon-ceramic option will be offered because they didn't perform as well as these steelies, especially in terms of fade resistance. We are told that no driver has managed to fade the brakes on any of the 15 private and public race courses the car has terrorized during the last 12 months of development. Randy Pobst: Consider that a challenge!
On "cooking-grade" GT350s, the aluminum wheels measure 10.5 x 19.0 inches in front, 11.0 x 19.0 inches in back, which is up from the 9.0-inch front and 9.5-inch rear wheels on the GT Perf Pack. But the big news is the GT350R's composite wheels. They measure 11.0 x 19.0 front, 11.5 x 19.0 rear and are astonishingly light. Firm specs and details about who supplies them are not yet ready for release, but figure they're in the 13- to 15-pound range, down from something closer to 50 for aluminum. They're so light that they affect the natural frequency of the suspension corner enough to require recalibration of damping, ABS and traction control systems. How susceptible are they to damage? Well, if you nail a pothole hard enough to bend an aluminum rim, you'll probably crunch the composite rim, too, but you won't initiate a crack that will quickly propagate and begin to leak, as happens with metal wheels, so if you can live with the looks, you might be able to drive for years on a damaged rim. These wheels account for a lot of the claimed 130-pound weight difference between an R and a base GT350. (The deleted rear seat, AC, and radio are the other biggies.)
Michelin worked in conjunction with Ford Performance to develop two performance-optimized tires for this latest Shelby. Base models wear 295/35R19 front and 305/35R19 rear Pilot Super Sport tires with unique sidewall construction, tread face, and compound formulation. Careful weight optimization means that these tires weigh about the same as the smaller GT Perf Pack tires. The R upgrades to 305/30R19 front and 315/30R19 rear Pilot Sport Cup 2 footwear. Will all this gear work well enough together — and with that screaming flat-plane-crank V-8 — to outmaneuver a Camaro Z/28 around Mazda Raceway Laguna Seca? We can't wait to let you know.
X-PIPE
It's not a chassis/suspension item, but we couldn't help noticing this X-shaped crossover pipe, which is unique to the GT350. The two main exhaust pipes are joined by an H-pipe on other Mustang V-8s. This one forces intermingling of the exhaust pulses coming from each bank, greatly enhancing the exhaust note coming out the back, whereas the H-pipe connection just equalizes pressures but largely sends the same music burbling down the same pipe it started in.
http://www.motortrend.com/roadtests/coupes/1505_2016_ford_shelby_gt350_mustang_chassis_first_look/
Edit: I think it might be working now. I'm sure all of this copying will probably have to be taken down.
Some good information here.
enzo101
Arkansas
Garrett
2017 GT350 R
Link doesn't work.
gt350
Saabaru
Good info
enzo101
Arkansas
Garrett
2017 GT350 R
This is awesome!!!! Thanks for sharing it.
Todd15Fastback
Atlanta, GA
Todd
2015 Mustang GT PP Fastback
Great info!! Nice to see the xpipe confirmed since we all could tell by the sound of the videos.
azsnake
Tucson
2010 Raptor
Finally I think we can lay the CCB theory to rest. I'm pretty sure if it was going to be an option it would have been mentioned here, and thus they wouldn't have said "No CCB will be offered". I'm glad to see that these brakes according to the article preform better than CCB's and that you don't necessarily have to toss 7 figures into brakes.
FPCV8YO
Rode Hard & Put Away Wet
South OC
2006 350Z GT Roadster
No CCBs!
Todd15Fastback
Atlanta, GA
Todd
13-15 lbs wheels. AMAZING!!!
Colleton
Mustang Fan
NW Florida
2020 GT500, 2017 Edge Sport, 2013 Focus ST
Great info, thanks!
Mystic_Cobra
Northern VA
2017 RR GT350, '65 Mustang Coupe
Great detail here. More, moar!
Topnotch
NYC
2018 Mazda CX-9 Touring
Topnotch
NYC
