What Dyno Tested "NA" Mods actually increase HP Above 500wp on 93 pump?
DougS550
DougS550
Indiana
Doug
My 18 put down 516 / 454 in April heat in AZ a while back. LTH, Flex tune but tested at e90, oem intake with drop in. But I also reduced rotational weight where I could to mitigate parasitic loss thus more to the wheels. CF DS, light weight wheels etc.
Nice set up. Thanks for the advice.
Paul's Pony
GA
Paul
2020 Mustang GT Premium, Magnetic, Showstopper Red
What about axles? If you add FI and get up to 600+HP at the wheels, aren't you asking for a broken axle particularly with the standard 3.15 rear end? Anybody have any experience with FI and the 3.15?
Jackson1320
Jaxson
2015 mustang gt
you shouldn't have any problems tell closer to 750-800
paulm1
Northeast PA
pau
2021 GT mustang
I'd be happy with 500 crank HP and a factory warranty still in tact.
LSchicago
Illinois
Lloyd
2018 Mustang GT/A 301A 5.0
Add GT350 axles for cheap insurance.
Andy13186
For 500 wheel I think you will need a very aggressive tune and octane booster if you arent using e85. Youll also need lightweight wheels, tires, driveshaft, brakes, full 3" exhaust, catless longtubes and cold weather.
BAYoung
Douglas, Wyoming
Brooks
2021 Mustang GT Premium 10 speed, rapid red, pp1,
Lighter wheels and such show gains on dynos? Did not know that.
Angrey
Coral Gables
2016 GT350
Big time. Best way to neuter a dyno run is to use Donk 22"s. I think tire type has an effect too, but I think that's less pronounced.
I've seen vids on import testing where going with a tiny wheel resulted in nearly 10% gains over big flashy wheels.
BAYoung
Douglas, Wyoming
Brooks
Yeah. Im looking at apex wheels, titanium lugnuts and wheel studs, carbon brakes front and rear with e brake deletes, front wilwood calipers that are 6 pounds lighter than the Brembo ones, and a cf driveshaft. Iirc Gforce Axles are about 1.3 pounds lighter than oem. Wonder if they count, too.
AZ18yote
Arizona
Bryan
2018 Mustang GT Prem PP Magnetic
Weight reduction on rotational mass results in less parasitic loss,
meaning you are not making more power, but you are putting more of the power you do make down to the wheels, IE more usable power.
Angrey
Coral Gables
2016 GT350
They're great for real world performance, but the only thing that affects the dyno is anything that has to rotate (i.e. wheels, tires, driveshaft, clutch, flywheel, etc). The brakes will definitely help with unsprung weight (which is more beneficial than sprung weight).
Remember, the motor has to fight inertia to get all those things in the driveline rotating faster and faster and so anything that lessens that results in more effort going to spinning the dyno roller (or more power to accelerating the vehicle in the real world).
The lightened rotational components shows up in more drivetrain efficiency and less losses on the dyno.
Lighter brakes and anything that's not spinning is great, but won't help HP numbers, but is just as effective as more horsepower (takes more energy to accelerate a heavy vehicle).
BAYoung
Douglas, Wyoming
Brooks
Ah. Okay. 515whp with a stock im/ intake setup is crazy. Im thinking i will be about the same with an ported IM, ported TB, and a steeda 121 intake. My biggest thing after that is cooling/ airflow. Mountain driving with up to 20k DA will be insane.
