Great question, even though our radiator is quite a bit thicker than the PP radiator, it still occupies the same general space. In the last photo that I posted above, you can see that there is quite a bit of space between where the oil cooler ends and where the AC condenser is located. The AC condenser will stay in the same location with our radiator so you can use the photo above for general reference as to where our components will be located.Will the cooler be compatible with your new aluminum radiator given the increased thickness?
Thanks for the kind words, if we need additional testing we will keep you in mind!It looks to be a great mod. Thank you!!!
*edit* if you need a first gen product tester let me know, available!
Thanks for your order!Ordering.
We will certainly keep that employee in mind if we need additional testing data!You should send one of these to that one vendor you guys work with in Utah... I think you know the one I mean, they have an employee who would love to test fit this for you ;)
Thanks for the kind words!Thumbs up!
We have not been able to test fit this or our radiator with any aftermarket supercharger setups yet. However, both of these products were designed with supercharger setups in mind. Our oil cooler sits flush with the wiring harness on the back of the crash beam to allow for the most room behind it. The radiator sits in its factory location and moves the fan shroud back about a half an inch to account for the larger core.I would assume that the oil cooler as well as your radiator are compatible with the Roush Phase 1 Supercharger kit? (In fact they both would be very helpful for S/C'd roadcourse duty, no?)
When can we expect test results? Thanks in advance for your contribution to the platform.
The stock oil cooler should be removed to use our oil cooler setup. However, with a thermostatic sandwich plate and our large heat exchanger, our setup was designed to be sufficient without the stock cooler.Any way to use this in combination with the stock oil cooler?
So that's a no lol. Kinda disappointing. I would think the more cooling the better. Any particular reason you decided to design it that way aside from it being "sufficient"?The stock oil cooler should be removed to use our oil cooler setup. However, with a thermostatic sandwich plate and our large heat exchanger, our setup was designed to be sufficient without the stock cooler.
-Sara
