Do you experience vibration and rumbling between 50 and 70 mph?
  • Total voters
    1,208
MikeD1
Central FL
2016 Challenger Hellcat
Did you have all three of the requirements for the Florida Lemon Law ?
For me to qualify I think they will have to get the car back 2 more times for this issue and the car might be over 2 years old by then
Yeah, I met the criteria in spades - < 1 yr old, 1300 miles, 6+ attempted repairs, 80+ days out of service. Ford never even bothered with the arbitration hearing, scheduled it, then cancelled it a week before the date & started the buy-back process.
15Pony
Jackson, MS
Bruce
2015 Mustang V6
Auto.
I was thinking that this mirror movement was odd and then found this amazing thread. Wish I'd found this thread BEFORE buying the car!
Friend of mine has a 09 GT and also has drive shaft vibrations.
My '15 V6 auto had the rearview mirror shake from day 1 (188 miles on the odo). They were not able to fix it and I did not press further on that. Sadly, that is a "feature" of all S550s.
hlh1
Central VA
2019 GT PP1 A10
I will say I just enjoyed a great driving day around Helen GA and all the great winding mountain roads. The only time I really noticed the driveline vibration was when cruising down the freeway on a smooth road. Otherwise it kinda gets lost in the road noise and bumps.
hlh1
Central VA
2019 GT PP1 A10
I'll be taking the GT in for an oil change in the next couple of weeks and I'll have them check the "vibration I feel in my seat" and see what comes of it.
hlh1
Central VA
2019 GT PP1 A10
Question: I understand through reading this thread that pinon angle is important. How much is this changed by loading up the vehicle with a passenger and luggage?
ANGST
Herndon VA
18 Cayman GTS, 15 Explorer Sport , 09 Honda Fit
Good question , I had always thought my vibration seemed less with a full tank of gas
Unadilla248
Pennsylvannia
7x
I tow a motorcycle with mine and Vibration is no better or worse.
HoosierDaddy
Randy
2016 GT Premium PP
The diff is mounted to the body so the pinion angle won't change, just the angles of the axles.
hlh1
Central VA
2019 GT PP1 A10
So, if there's any increased noise or vibration with a "load" it could be related to the axles in this situation?
hlh1
Central VA
2019 GT PP1 A10
The yellow dots on the drive shaft, are they on the transmission or differential end?
hlh1
Central VA
2019 GT PP1 A10
hlh1
Central VA
2019 GT PP1 A10
Ok, finally crawled under my GT and see this. Are these marks far enough wrong to cause a vibration?
Dominant1
Dr Frankenstang
2016 gt/cs auto 3:55 gears
Dont know but reclock it to line the dots up and see what happens!
lugz
NC
2017 Mustang GT PP
The dots aren't lined up because there's only 6 positions the DS can have in the yoke. The factory got it as close as possible. You might try to reclock it one bolt hole over - you still won't be perfectly lined up, but might make it better.
