nala1908
- May 29, 2014
- Chicagoland
- 2015 EB Premium PP
Has there been any research done into making a VGT turbo kit for the EB?
From what I remember it changes the aspect ratio based on rpm and load. So you get the low end quick spool of a small turbo and the top end of of a big turbo.What's that?
Kinda the best of both worlds.From what I remember it changes the aspect ratio based on rpm and load. So you get the low end quick spool of a small turbo and the top end of of a big turbo.
I think I read that the newer Cummins Dodge Rams have this style of turbo.
I remember the 997 Turbos were the first gasoline cars to use them, I imagine Porsche still uses them now (?). They aren't used on most gasoline vehicles because the EGTs are too high if I remember correctly.From what I remember it changes the aspect ratio based on rpm and load. So you get the low end quick spool of a small turbo and the top end of of a big turbo.
I think you're right.I remember the 997 Turbos were the first gasoline cars to use them, I imagine Porsche still uses them now (?). They aren't used on most gasoline vehicles because the EGTs are too high if I remember correctly.
