OVRKILL
Hey folks! I just completed my heel/toe pedal installation; it took about an hour. This unit is a 3" wide billet aluminum plate which bolts directly to the stock pedal. It provides a nice wide surface so that you can easily blip the throttle with the side of your foot.
I'm personally fond of the aesthetics, and the wide, grippy pedal feels nice during typical use. It makes heel-toe revmatching much easier. For $25, I'm pretty happy.
Some nitpicks:
When aligned properly, only three of the plate's mounting holes sit flush against the plastic surface of the pedal. I used these locations, but I would have preferred having the holes drilled in a six-pack arrangement. This would be, of course, overkill, and only using three holes is not a major issue.
I had to do some cutting to make the nuts fit on the plastic. This could be prevented with longer bolts and wedges, or different bolt locations.
I do appreciate that nylock nuts were included. Some small washers would be nice to have. ;)
I think I'm going to get the other two pedals as well, so I can grip tape them. I sometimes feel like my foot is going to slip off of the brake pedal when I'm rev-matching with the sides of my foot.
Here's an imgur album with a few pictures from the install process.
http://imgur.com/a/XtNCC
Some nitpicks:
