S550 Diff cooler build overview, electrical instal, and An fittings
Good write up! I'm sure it will benefit others in the future for open track events where rear differential temps can be excessive.
Where you able to document before and after temps using the factory rear differential readout in the dash cluster?
1 old racer
1 old racer
Fontana CA
Will
Thanks and not yet. Please note, that the first layer of heat protection is to install header wrap on the exhaust pipes that goes around the diff. To most that will be enough. But for those that really push it for several sessions in a day, using a diff cooler is the best way to start that next session at the lowest possible temp. There are other ways to achieve this, such as jacking the rear of the car up and playing a high vol. fan under the car directed at the diff to get the air moving down there. As you push your mustang pick the best method that fits you the best.
1 old racer
1 old racer
Fontana CA
Will
I added the uncut video of the electrical install
Rapid Red
Woodstock GA
Greg
Hi Will
Great reference & build video, just the type of thing I like. :thumbsup: Book marked this, the parts information supplied, most valuable.
Laughed when you mention plumbing being half the price of the parts......... Boy do I ever know that is true. Have a drawer (small) full. Like Aeroquip cause they are reusable. And having purchased braided line by the box, got the plumbing . Check valve nice touch....
Very well done
And thank you
Greg
been playing
1 old racer
1 old racer
Fontana CA
Will
Thank you RR. And the header wrap does a great job till you get fast that is when you need the extra help.
Rapid Red
Woodstock GA
Greg
A picture of crawling before walking. Was going to ask about the rear cover, thinking it was plain. And where to find the cover with ports for the oil lines.
Remembered I took this picture and it answered my question, thank you Ford.....
Cheers
1 old racer
1 old racer
Fontana CA
Will
good luck and if you have any questions jut let me know. one other option you can consider is to put the pump in the spare tire well and the cooler under the car right behind the swaybar.
Rapid Red
Woodstock GA
Greg
Good thought, think I remember a flat area that has some device offset to the side, in that area.
Going to look for a way to make the wire runs on the under side. Not looking forward to pulling the interior apart The tattoo on the arm, same one the sound tube makes :devil:
1 old racer
1 old racer
Fontana CA
Will
and now about AN fittings
trackd
CA
August
19 GT PP2 (SOLD), 73 240Z RB26DETT
Has anybody tried to add air ducting directed to the diff? I imagine even small diam tubing 3-4”, not to affect clearance, might help while tracking at speed. Thoughts?
shogun32
Northern VA
won't work. all of the air in the vicinity is already quite hot. and furthermore cast iron is HORRIBLE at shedding heat. You need surface area and the only way to do that is to get a finned back plate (about $500 from M6G member) or a radiator.
Bossdog
Michigan
2019 GT PP2
have you ever checked what the trunk temp equalizes at on a hot day at the track?
1 old racer
1 old racer
Fontana CA
Will
At the end of a 2nd session on a 80 deg day the trunk temp was 10 deg warmer the the floor behind the driver's seat. If that tell anything. I should mention that I turned the cooler on on the cool down lap and left it on for about 10 mins after I parked in the pit area.
I did relocate it to under the car because I am not going to be tracking the car for at least a year and I need my trunk's tire well to store my spare. I dont like it there because I truly do feel the spare tire well provides the best place to keep the pump cool and it does get a lot of air flow with the windows down and the rear seat down
GTP
Deutsche Pony
Indy
www.BambergAudio.com
Philip
Will, do you have a diagram and/or parts list for your build? I am planning my own DIY kit right now, (-6AN lines).
Specifically looking for the check valve and its location.
1 old racer
1 old racer
Fontana CA
Will
Do you want a under the car install or spare tire well install. I can provide both later tonight
