It isn't based on a CD4, there aren't any platform structure or major components in common at all. That rumor was only started by people who think that because a car comes out the same door of a factory that it must be built the same underneath and inside.And if the car is based on CD4, as many rumors have said, would it be "clean sheet" in your eyes?
Great info. This thread is becoming very informative.The S197 is a devolution of the DEW98, which was co-developed with Jaguar in the mid-nineties and came to market in 1999 as the Lincoln LS and Jaguar S-Type (and later the Thunderbird, and later yet if the plans had gone thru would have been the new Mustang). The previous gen SN95 was a slightly modified FOX platform which was developed starting in the early seventies and came to market in the fall of 1977 as a 1978 Fairmont and lasted all the way into the 2004 model year - wretched as it was by then (so 2004 buyers were driving 30 year old technology that had been repeatedly patched up - one dead end was the gas tank location). The Panther platform was an even worse example. So there is plenty of precedent here. Each of the steps in the use of those platforms was marketed as "all new", and they may have had major modifications (the Panther went thru multiple suspension upgrades, for example, and those model years were marketed as "all new"), but none were clean sheet.
All the evidence of the early mules and the current prototypes show that the S550 is an evolved S197. It's very plain to see via some easy analysis. Ford Marketing and sales will beg to differ, as car manufacturers always do. That's their business method. But there is something else at play here, a social factor, something about pride, which dictates to some people that the 2015 has to be "all new" and that it is some sort of personal affront if it isn't. "The Emperor's New Clothes" is an old tale, and car manufactures use it to their advantage. If you believe the clothes are indeed new, you are falling prey to their trickery. ...........
But for the sake of argument, if it is a CD4, then it is all-new to Mustang fans, but not clean-sheet since it's just a Fusion behind the scenes. And it would also be extremely undesirable.
We know the next Camaro is built on the Alpha chassis, so it's "all-new" to Camaro fanboys, but it's not an all-new car given the use of the Alpha for the ATS and CTS. They'll have the same argument on their forums, bemoaning anybody that says their emperor has no clothes, while chest-thumping and giving the rebel yell. But the difference is there that they are getting what was a clean-sheet platform, designed from the start for this purpose, light weight and efficient, and offering benefits all around in quality and component choice. A big discussion they are having is whether or not the next Camaro should get the twin-turbo V-6... that is up to marketeers. But the Alpha platform makes that possible and easy if that is to happen at all.
For the uninitiated if you could explain how it is you can tell (apparently just by looking at the pics unless you have actually examined real life physical parts) this is just an evolved S197 by looking at the early mules and current prototypes. I'm not saying it isn't but how can you tell so easily?All the evidence of the early mules and the current prototypes show that the S550 is an evolved S197. It's very plain to see via some easy analysis. Ford Marketing and sales will beg to differ, as car manufacturers always do. That's their business method. But there is something else at play here, a social factor, something about pride, which dictates to some people that the 2015 has to be "all new" and that it is some sort of personal affront if it isn't. "The Emperor's New Clothes" is an old tale, and car manufactures use it to their advantage. If you believe the clothes are indeed new, you are falling prey to their trickery.
Because CD4 is a front wheel drive car. Look under the hood - how could you fit an inline engine under there (with all the structural requirements, and crash protection, etc)? Would the frame even be strong enough? Would the suspension parts be strong enough? Would the resulting weight distribution be reasonable? The answer across the board is a resounding "no". The entire idea that this is a CD4 is absurdly ridiculous.For the sake of argument then, if CD4 going to Mustang is undesirable, why isn't Alpha (used on a sedan as well) undesirable for Camaro?
Again, playing devil's advocate, you couldn't tweak CD4 to fit a larger variety of vehicles? You couldn't, say, use a longer front clip to accomodate a RWD vehicle? Or, you couldn't stretch the platform for a big sedan (Taurus/MKS) or heighten it for a crossover (Edge/MKX)? If you can do one, you certainly can do the other. Using an evolution of S197 makes NO sense in the future, because, yet again, it would be used for ONE vehicle. While I'm not a body design engineer, I can't see why one couldn't create modular "parts" of CD4 and plug and play each bit in to create the ideal platform for a variety of vehicles in the lineup. This way, as you mentioned, you can "check the box" and add any feature you like, without having massive expenses for development because of the limited nature of the platform.Because CD4 is a front wheel drive car. Look under the hood - how could you fit an inline engine under there (with all the structural requirements, and crash protection, etc)? Would the frame even be strong enough? Would the suspension parts be strong enough? Would the resulting weight distribution be reasonable? The answer across the board is a resounding "no". The entire idea that this is a CD4 is absurdly ridiculous.
The Alpha is clean-sheet, designed to accommodate everything from an inline 4 to a V-8, and different widths and lengths bodies. And it's rear-wheel drive based, inline engines, with accommodation for an AWD front take-off (and probably a battery pack as well). We haven't yet seen it in any form other than the 4-door ATS and CTS, but we know that 2-doors are in the plan and coming. A 2-door ATS mule has already been seen, and Chevy teased us with a 2-door "135"-type concept. The Alpha shares nothing with any previous design, except obviously the existing engine programs. So, clean sheet, no baggage, no hang-ups, very nearly a state-of-the-art suspension design all around (except for the struts up front). And designed from the start to be shared so that every user of the platform benefits. Need an inline turbo 4? Check the box: it and it's systems are already developed and ready to go. Need magnetoreological shocks? Check the box. Big brakes? Again, check the box, they're already developed for all users. Twin-turbo V-8? Check the box, it's already developed for the CTS-V. All these things aren't much more work than simply plugging them in (of course, things like spring rates are model-specific). The financial advantages here are tremendous.
As I said before, there is already an even better example of this, and it's the FM platform from Nissan. Used on the 370Z and most of the Infinitis. It handles 1 family of V-6 engines and 2 different V-8s. It allows for AWD, and also accommodates a battery pack for the two cars that offer it. And the GT-R is also a user of the platform (although it diverges in the rear transmission and suspension). Every single user of the platform benefits in costs, each benefits in fatter margins, each can use a wider range of engines and transmissions as they are developed.
This is where Ford blew it several times with the Mustang. They were going to share the MN12, and then it was the DEW98. Now they have the opportunity to get this right, and to reap the benefits for all users of the platform. It isn't optimum, because it isn't a clean-sheet platform to begin with, but it could be a start.
So do you think that is a bad thing, a good thing, or neither?This is so rediculous. The car is an evolution of the s197. Get over it.
I look forward to seeing whose theorizing proves to be accurate. While I also think this might be true about an S197 evolution, I read what others have posted with interest. Unless you work for Ford, summarily dismissing the CD4 evolution conversation is a bit premature. Besides, this type of conversation, while perhaps maddening for some, is as much entertainment as eye opening until we see what covers the bones. Drop that camouflage, Ford! :-)This is so rediculous. The car is an evolution of the s197. Get over it.
Leave him be... His entire Driver Enthusiast site argument was based on an "evolved S197". While it seems great the Camaro will use an ATS chassis, at least Ford isn't drilling holes in the safety structure....For the sake of argument then, if CD4 going to Mustang is undesirable, why isn't Alpha (used on a sedan as well) undesirable for Camaro?
Its a budget reality... nothing more.So do you think that is a bad thing, a good thing, or neither?
I think the Ford engineers are probably busy working on the car.S550Boss said:Your continued misinformation degrades this forum... The Ford engineers are laughing over it. And it plays right into their hands.
