sanchezcruz_20
- Apr 10, 2015
- Columbus, OH
- 2015 Ford Mustang GT
Fuel System
The kit includes larger fuel injectors that need to be installed. Before attempting, I depressurized the system by pulling the fuel pump relay (I believe it was #49 in the engine compartment fuse panel) and starting the car. The car will either simply crank the motor or run for only a few seconds until the residual fuel is removed.
The fuel rail is held in place by 4 bolts and can be removed as an assembly and taken to a clean work surface to swap in the supplied injectors. Simply unclip each injector and install the new ones. A few drops of clean engine oil is recommended on the injector o-rings to help fully seat them.
Then reassemble the fuel system using the PC supplied fuel rail spacers.
