Zinc03svt
I was going wot @ 100 miles on the clock. Changed oil @ 3100 miles PUP 5w20. Mild occasional tick started 2000 miles w/ no rattle. Burns zero oil now at 6000 miles. Motor is strong...
I went WOT pulling off the dealer lot, took it to the drag strip at 200 miles, oil change at 1100 miles, and a road racing track day at 1300 miles. Currently at 13,000 miles, same mild ticking and rattling it had when I bought it, no oil being burned, no misfires, nothing at all wrong with the carI was going wot @ 100 miles on the clock. Changed oil @ 3100 miles PUP 5w20. Mild occasional tick started 2000 miles w/ no rattle. Burns zero oil now at 6000 miles. Motor is strong...
Change the oil before you track it the first timeWhat does that mean? No break-in at all just drive it like it has 5k on the clock? if so, is he the lead tech for the local bowling alley? I would say that once broken in, they should be driven hard....why else would you buy one?
As for me, I have about 500 miles on it and am driving it to break it in....engine, tranny, etc. Once I hit a grand I will start to ease into driving it like a Mustang should be. At 1200 or so, it will be on the track doing its best imitation (limited more so by me) of a race car!
My rule of thumb is similar. Don't get within 1500rpm of redline on factory oil. Change out factory oil at the end of manuals breaking period.Change the oil before you track it the first time
Yes exactly....I should have mentioned that as well....thanks for bringing it up :-)Change the oil before you track it the first time
It’s pretty clear this is right or else we would be seeing more actual engine failures. Not necessarily the replacements that were happening early on, but full on failures. My major issue comes from years of knowing that knocks, rattles, and ticks are mechanical problems with an engine. Now the manufacturer, whose sole purpose is to make money, comes along and says “everything is fine, don’t worry about it”. Before Ford even came out and said it was normal people were getting the cold shoulder from dealers. I had to go to my dealer three times before they would even write the car up as being seen.I am saying that some rattles and ticks may be normal, or inside the spectrum of what is "normal".
before my short block was replaced due to tick, I remember the pattern - one engine start out of 5-7 mightve been tick free.Drove it around Sunday a bit and not a peep. I'm guessing there is something in the engine (on some of these cars at least) that loses oil pressure momentarily or doesn't pump up pressure right away, if that makes sense. A plain old mechanical issue should manifest itself in the same way each time the car is driven, if cycled through the same temps. I come from years of driving Hondas, and let me tell you, my Coyote is quiet in comparison. My Hondas rattle a good bit when cold, valve clearance. Even after a valve adjustment it's there.
I'm NOT saying all of the sounds are in people's heads (I've seen enough things posted here and elsewhere to indicate there has been damage in at least some cases), but I am saying that some rattles and ticks may be normal, or inside the spectrum of what is "normal".
What was the final diagnosis from the dealer on your ticking engine?before my short block was replaced due to tick, I remember the pattern - one engine start out of 5-7 mightve been tick free.
for as long as I kept engine running I couldn't reproduce the tick even at i door parking lots or other special places.
next time I started the car- the tick would be there and no way you could get rid of it.
They localized the tick to a particular cylinder by canceling cylinders one by one. Bot sure what the procedure is. After that got approval from ford for a replacement.What was the final diagnosis from the dealer on your ticking engine?
Thanks.They localized the tick to a particular cylinder by canceling cylinders one by one. Bot sure what the procedure is. After that got approval from ford for a replacement.
New block did not tick, then I added ceratec pretty soon.
As far as #1 - did not get details. #2 the tick was very reproducible. #3 - it stayed at the same level.Thanks.
Three questions:
Was it a failure of a bearing or what part, or did they tell you?
Was the tick persistent when it manifested, or did it appear for a while and quiet down?
Did it get worse over time?
Thanks.
Three questions:
Thanks for taking the time to respond to me peppering you with questions.As far as #1 - did not get details. #2 the tick was very reproducible. #3 - it stayed at the same level.
