TexasRebel
Gearshifter
- Mar 19, 2016
- between the mustard and the mayo
- 2016 YZ GTPP - PP2
I generally find the link to the .zip and use wget in linux.
I had the same problems, but got it to work today by logging out, then clicking on button that I forgot my password. This leads you to a screen where you enter your email and they send you a temp password. Then I was able to log in and download the update.Tried that also. Also different browsers. Still a no go. I am assuming that when you press the "Start SYNC Update" it should download the update files to your computer, right?
no not right away...after the 'Begin SYNC Update' theres a new page that opens with the instructions on how to do it, at the bottom of that it says start download.Tried that also. Also different browsers. Still a no go. I am assuming that when you press the "Start SYNC Update" it should download the update files to your computer, right?
Yes, for me after you click "Begin SYNC Update" it does go to a page that says "SYNC Software Update" at the top, but the page is all grayed out and that blue/white loading circle appears and nothing happens.no not right away...after the 'Begin SYNC Update' theres a new page that opens with the instructions on how to do it, at the bottom of that it says start download.
Try turning the automatic system updates setting to off.Anyone have an issue with the "SYNC can connect to Wifi" popup every time you start the car? Any way to get rid of it other than turning off the wifi?
Post #4850Anyone have an issue with the "SYNC can connect to Wifi" popup every time you start the car? Any way to get rid of it other than turning off the wifi?
I updated my iPhone yesterday and Waze worked fine today when I was using it.Anyone had an issue with Waze not being available for iOS after the update?
Did you wait for at least 5-7 minutes after you inserted the flash drive? That’s how long it takes before you see any message that an update is in progress.Anyone have an issue where even if you have the update on your USB, it does not come up when plugged into the USB port? I only have tried one flash drive right now. I know the flash drive works, but SYNC does not start updating. Could it be that I am still 2.2 and need to go to 2.3, then to 3.0?
No, I did not wait that long. The instructions said that it should come up almost immediately. I may give it a try again today, see if it pops up after a few minutes. Just to make sure, it took 5-7 minutes just to detect your flash and acknowledge that there is an update on it? You did not have any other notifications related to the update or USB before that?Did you wait for at least 5-7 minutes after you inserted the flash drive? That’s how long it takes before you see any message that an update is in progress.
Yeah, I made sure to have my flash in FAT32 before I placed the files onto it. I may try to wait longer or a different flash.The message doesn't appear until the tarballs have been extracted from the drive to the APIM.
If you're using exFAT stop. Format it with FAT32. On some drives the exFAT formatting will potentially slow down the read speeds to 100 kBps or less.
