fionic
spaghettios and cheerios
you'd need a hardware upgrade for mycolor I'd think. then enable it perhapsAre there any premium options that can be enabled such as Mycolor, or is that generally a hardware upgrade as well?
this is one that could probably be done. just gotta find it... compare GT350 tech/base to Track/R AS-BUILT data and see the diffIt would be cool if us 2016 GT350 Tech and Base owners could turn on transmission temp monitoring in the dash. The car is doing it, but for some reason Ford decided to only leave it on for Track and R owners.
not quite the same and you then lose all the standard gauges :/ still nice, thoughDon't know if it well help any, but if you hold down left Ok button while starting the car, engineering test mode will display and has a digital speedometer.:shrug:
Possiblyalready confirmed by [MENTION=23778]AngelDeath[/MENTION]
also AngelDeath, is the checksum off in the Simultaneous High Beams & Fog Lights or am I losing my base16 adding skills?
I took them from the post you made :/Possibly
726-27-02
07+26=2D+27=54+02=56
I just noticed you have the enabled and disabled values reversed.
it disables interior lights and puddles from turning on when you open door/ turn off car. (afaik)What exactly does police dark mode disable? Just interior lights? Or other lights as well? Such as puddle lights
Yes the sheet is incorrect. The others check out.Possibly
726-27-02
0726 27 01 0100 0001 0058
0726 27 01 0100 0000 0057
0726 27 01 0100 0001 0057
0726 27 01 0100 0000 0056
so the checksum is the thing that is off, not the change itself. good.Yes the sheet is incorrect. The others check out.
should beCode:0726 27 01 0100 0001 0058 0726 27 01 0100 0000 0057
Code:0726 27 01 0100 0001 0057 0726 27 01 0100 0000 0056
How long do you have to hold it down? I just tried this a few times and nothing happened.Don't know if it well help any, but if you hold down left Ok button while starting the car, engineering test mode will display and has a digital speedometer.:shrug:
until after the car is started, round bout 5 seconds I think.How long do you have to hold it down? I just tried this a few times and nothing happened.
