I really hope so too. I don’t necessary have a part number. But I got them from American Muscle:Really
Hoping this does it for you! That is likely my next move as well.
Got a part number for them? Where did you order from?
Thanks!
Very interesting, I did notice quite a bit of oil residue in the old intake manifold (no catch cans). But I changed out the plugs and the original plugs looked pretty new so I don’t think fouled spark plugs is my issue. I will be getting catch cans for sure asap. But I want to fix the misfire before anythingI had issues very similar. I had a guy in my area that was awesome with knowledge on the coyote. My issue ended up being oil in the intake manifold, that migrated down to foul my plugs. Got new plugs, pcv valve and catch cans passenger and driver side. Havent had an issue since.
I dont know if you looked down the spark plug holes to see if there was any residue or oil in the holes.Very interesting, I did notice quite a bit of oil residue in the old intake manifold (no catch cans). But I changed out the plugs and the original plugs looked pretty new so I don’t think fouled spark plugs is my issue. I will be getting catch cans for sure asap. But I want to fix the misfire before anything
i might have to look into this when I put the car back together. I have the Valve covers off and waiting for parts to come in has I am also going to replace all camshaft position sensors (2 intake and 2 exhaust) along with the vct sensors It’s a waiting game at this pointHave you looked into replacing the fuel injector wiring harness?
I have a suspicion this might be pinching or somewhat broken wire in the coil or injector system.
If you know someone that has a scope you could tap in and watch the injector or coil signals in real time.
New plugs. Cleaned injectors, smoke test x2, cleaned MAF, new TB, switched coils around x4, compression test, scoped the cylinders, KAM reset x3, crank relearn x4, numerous logs and mode 6 data.At this point, I haven’t come with a plan yet. I am running out of options. What have you done so far?
