MCcloud RXT or OEM clutch
WCKD350
Laguna Nigeul CA
Sina
2017 GT350 / tricky performance E85 tuned
Hey, My stock clutch has been having some serious issues lately. I have decided it’s time to get in there and do a replacement. Is getting a MCcloud RXT clutch with a light bolt on car a waste of money / overkill . Currently i’m only E85 tune, Cat deletes, Ford performance intake, Mickey thompson tires. My end goal is really only to get long tube headers and a Cobra Jet manifold. Would the OEM clutch be sufficient?
beefcake
Bethel
2018 Ford Mustang
are you drag racing the car,
for street driving, mcleod rst or vengeance stage 1
if you are doing clutch dumps or burnouts, then rxt or vengeance stage 2 is what you want
beef
WCKD350
WCKD350
Laguna Nigeul CA
Sina
beef
I am not doing any serious drag racing the 350 is mainly a roll race car for me. I called MCcloud this morning and apparently they don’t have an RST only an RXT for the GT350. But i think that vengeance stg 1 might be more fitting for my setup. My only question is would i be able to flat foot shift the vengeance clutch with a proper tune of course.
Thanks guys
Inthehighdesert
NM
Charlie
The McLeod has an oem feel, but the engagement point is a little more to the top. Excellent on the street once you get use to the engagement point. I have one with 900 miles on it for sale in the member for sale transmission section.
Justgonna send it
Winston-Salem
Ty
2019 GT 6spd
Thanks guys
I’m 800 miles in on the vengeance clutch. With steeda spring lets out around mid-top. Drive close to stock but grabs much Better. And that flywheel don’t get me started 🤩🤩🤩
WCKD350
WCKD350
Laguna Nigeul CA
Sina
I’ll be getting that stg 1 for sure beefcake got me hooked up 🙏
SCalla0490
MA
United States
beef
With the vengeance stg 1 clutch, will the clutch work okay for drag racing with drag radials (not dumping the clutch)? My previous coyote I had a mcleod RST (organic discs) and after a burnout, that clutch would not slip. Acted as an on/off switch. Bent an axle from not expecting it lol
beefcake
Bethel
2018 Ford Mustang
you need astage 2 or rxt for drag racing organic material does not hold up to burnouts or clutch dumps
SCalla0490
MA
United States
The RXT I also had would do the same thing. Trying to slip the clutch at 5000rpm on drag radials, it would just engage. I then went to a spec 2+ (Kevlar/carbon ceramic) and that clutch was perfect. I could slip it at 5k rpm no problem.
MHW100
Nanaimo
Matthew
2021 Roush Stage 3
I just purchased a 2017 which has the rxt 1,200 in it. The previous owner had an issue with the oem and replaced it.
My concern is that not being stock the Ford ESP might be voided if the engine failed. Is that a possibility? I don’t really want to pay for an oem clutch and flywheel but better than a voided warranty $30k.
Inthehighdesert
NM
Charlie
I highly doubt you have anything to worry about. I’d be surprised actually if a tech even actually looked twice at the clutch if your engine went south.
Turbolag87
Toronto
My18 gt
My RST is a nice clutch, but it slipped on my first race on e85 on 10psi... should of bought and rxt. Selling my clutch if interested lol... it has 1400 km
beefcake
Bethel
2018 Ford Mustang
The RXT definitely holds up to the heat better, especially if you go to the strip
Feel free to DM me and I’ll help you out on a replacement
