- Dec 19, 2014
- Website
- www.uprproducts.com
- Joe
- UPR 2015 Ecoboost Mustang
We offer a fix for the vacuum issue and PCV valve. The 2018+ problems stemmed from cylinder wall coating issues, looser ring gap, and a PCV valve that lets in too much air/vacuum, which pulls oil vapors. We have dealt with thousands of customers with this exact problem. The throttle trimming during cost/deceleration was an afterthought.
So we developed a UPR Adjustable PCV valve that can be adjusted to reduce the amount of vacuum, which has been extremely beneficial for 2018 Coyote engines in both the Mustang and the F150 trucks.
You install the UPR Adjustable PCV valve and start with the second-to-smallest jet, and you can start enjoying the improvement instantly. If your 5.0 Mustang or 5.0 F150 uses excessive oil, you can just install the smallest jet and never look back, enjoying your vehicle as intended.
Just wanted to share this as it has been a common issue since the 2018 motor was released.
The part number for the UPR adjustable PCV valve is 5045-24, and you can use coupon code (Mustang6G)
Joe@UPR
Joe@UPR
