doodguy
- Jul 8, 2015
- Ruskin, FL
- 2015 Roush Stage 1 Supercharged Mustang GT
With the fuel line removed, I thought it would be a good idea to clip my steel braided clutch line where the factory fuel line use to be.
Now due to the depth of the frame, and being able to put the plastic shielding back on you have to run the fore fuel lines along the brake lines. So run the lines from the top of the fuel tank down along the brake lines through the drivers side wheel well up into the engine bay.
In my case, I had 2 fuel lines. One is noticeably thicker than the other. I connected the fore fuel filter at the part where I had the most depth for protection from the ground up towards the front of the car.
Now this part sucked. There is plastic sheathing in the middle of the steel braided line. If you're not careful this thing becomes like a chinese finger trap and tightens up gets hard to fit the brass ring inside it. This is hard to describe but if you look inside the brass ring there are like 3 ridges. You want to put this brass ring over the plastic sheathing but on the inside of the steel braided line to the 3rd ridge. Then you slide the black fitting inside the steel braided line and screw it together. Next you screw this into the fuel filter etc. If anyone could PM me a good youtube video for how to do this I will edit this with that information.
With the lines in place, connect the lines. The fat line (Line with the fuel filter) goes from Feed on the fuel pump to the rear drivers side fuel rail. Then you make a connection with the thinner line from the drivers side front fuel rail to the passenger side front fuel rail. Finally you connect from the passenger side rear fuel rail to your regulator where it does not have a label. Lastly, you connect the thin fuel rail from your gas tank to the regulator labeled return.
I will attach a diagram to try to clarify this. Sorry for it not being very neat.
