ramirj2
- Jul 30, 2014
- Bayamon PR
- 2015 GT premium, 2003 350z, 1978 280z
Hi!
“Finished” installing my Stage 2 with dual fans in conjunction with OPG,CG and ATI Damper.
After flashing the car, It started right up but very rough, tumbling and not able to keep a healthy idle.
I got the following codes;
P0098 – air intake temperature sensor 2 high
P0345 – camshaft position sensor A circuit malfunction
P0349 – camshaft position sensor A circuit intermittent
P0390 – camshaft position sensor B circuit malfunction
P0394 - camshaft position sensor B circuit intermittent
P068A – ECM Power relay load circuit – DE energized Performance too early (That one is the normal one after a flash)
I should have installed the OPG, CG before the Whipple in 2 stages but didn’t :doh:
Any way after contacting Whipple and looking back at the wiring ect. It seems I could have messed up the timing.
I thought that I followed the timing procedure correctly but apparently not.
Any inputs or help before I open up the timing cover would be appreciated.
Is there any other procedure available to check if the timing is not correct and how to put it back on track (other than the one to take the chains in and out with the marks)?
Thanks!
Thanks!
