Guys running e85
db252
Equinsu Ocha
Bay Area, CA
16 GT Premium/PP/Nav
Installing my Fore E85 complete fuel system this week and appreciate all the tips.
dubster99
Nor*Cal
2015 Ingot Silver GT PP
Never had any issues with e85 here and any gunk on the injectors. I daily drove it for a year and a half on e85 before going supercharged and my injectors looked perfect when I pulled them. Not sure if you're talking about deposits in the motor, but I've seen motors torn down with 80k+ of e85 use and they're spotless.
higdominator
Central Oklahoma
2016 GT PPP
I suspect goo is from something other than the ethanol. Hints at it cleanings remnants from gasoline use seem plausible. E is a pretty solid solvent.
Due to its inherent properties, E needs a little help in the lubricity side of things. I run a top end lube generally found in alcohol cars. Maybe a few ounces to a tank every 3 months or so. Plus it smells great (grape is where it's at).
I haven't had a pump gas car since E became a thing and have never had this issue.
dubster99
Nor*Cal
That's my theory too. People that drive xxxxx miles on regular pump gas and then switch to ethanol, it cleans out the sludge and shit in the tank and transfers it down the line. What lube do you run?
mustang_guy
United States
it has an engine!
He mentions it smells of grape. So it's most likely Manhattan oil, groovy grape. I find the Lucas fuel cleaner to work better and much cheaper, it's also an upper cylinder lube. 1 gallon is 20-30 bucks and treats roughly 625 gallons of gas.
beefcake
Bethel
2018 Ford Mustang
fore fuel system, good filter, lucas conditioner, what we run, and then some occassional race gas / pump to clean the system
Barrel
Hoonigan
Cars and Trucks
Stupid question I guess but since these are known issues with E85, why don't the ethanol distributors add these conditioners/additives to the fuels the same as they do with gasoline?
diablomatt
Sanford, FL
2015 s550 gt procharged,2012 GT F1X Procharged
For what its worth, i use the lucas stabilizer (green stuff) extensively in all our builds. my car has sat for almost a year on 3 different occasions and both time it fired right up with the old fuel and ran perfect. i JUST had my ID2000's sent to boost lab to have them checked and cleaned and they were almost perfect so i FIRMLY believe in the product. the main thing it does is all lubricant to the fuel and it keeps moisture at bay. the two most important things.
dubster99
Nor*Cal
I guess there's not enough oil being introduced into the fuel to negatively affect octane rating.
higdominator
Central Oklahoma
2016 GT PPP
Yeah, I run thdon’t Manhattan Top End Lube https://pitstopusa.com/i-5067221-po...-16-oz-grape-fragrance-treats-55-gallons.html
I get it stupid cheap locally so that what i run with. I get 3-4 treatments per bottle IIRC.
dubster99
Nor*Cal
Barrel
Hoonigan
Cars and Trucks
Checked every injector and they looked pristine...brand new. So...guess I'll just keep an eye out.
MustangGuy
Denver USA
2016 Mustang GT 401A 6M Ruby Red
So do you have to upgrade the entire fuel system (pump, lines, rails, etc.) to run E85?
Tommy V
Brookly park Md
Tommy
If your car is stock and your talking about running a power adder,yes u need Injectors pumps and new lines.U can use the stock rails.
MustangGuy
Denver USA
If your car is stock and your talking about running a power adder,yes u need Injectors pumps and new lines.U can use the stock rails.[/QUOTE
No power adder. NA. I probably posted this in the wrong section and just did a search for "Running E85". Just trying to determine if the stock fuel system pump, lines and filter are adequate. I know you're supposed to change out the injectors for 47lb's.
