Barrelrolll
- Feb 20, 2017
- Indianapolis, IN
- 2015 Mustang GT PP COMP ORANGE
Hello everyone,
My 2015 GT PP with a P1SC HO system died on me today on my commute home. I have ID1050x injectors along with the non-programmable vortech BAP running a Lund tune. I have had the procharger on for over 5000 problem free miles so far and have loved every second of it - until today.
I was less than a mile from home while coasting on an off ramp when my rpms dropped to 0. I tried restarting while coasting and the engine cranked and fired, but ran rough and would not respond to any throttle input and CEL popped on. I coasted to the shoulder and luckily a flatbed tow truck was nearby and was able to get the car home. I used my old X4 handheld to run the code and it came back with:
U0109 - Lost communication with fuel pump control module A
and
P025A - Fuel pump module A control circuit/open
So I am fairly sure that something is up with the BAP. I installed it using the correct gauge wire with heat shrink butt connectors. This literally just happened 30 minutes ago and searching the codes on this forum came back with nothing, so I was hoping that some of you fellas might have some advice. I am going to go check the fuses and all of the BAP connections. If that turns up nothing should I try and take out the BAP completely and rewire the pump like stock?
Thanks in advance!
and
Thanks in advance!
