GT_MTL
- Nov 19, 2021
- Montreal, Canada
- Yves
- 2018 GT Premium - 2018 F-150 XLT
Sent you an MP, just in case you didn't see itOui monsieur
Outgassing pads is a relic of historyI always thought the holes and slots were there solely for gasses to escape under high speed braking, otherwise the pad will “float” on the gas causing brake fade.
Fair enough, but I can’t see how there could be any benefit beyond that. Besides esthetics anyway.Outgassing pads is a relic of history
Ford fixed this is the later years of S550. I have a non-PP 2022 and I have the proper rotors. So they are available for the earlier cars that have the reverse rotor designREVERSE ROTOR DESIGN. the cooler vains are outside while should be inside.
Good info here. Thanks for sharing.Ford fixed this is the later years of S550. I have a non-PP 2022 and I have the proper rotors. So they are available for the earlier cars that have the reverse rotor design
Rears are still reversed. Couldn’t get a good pic on my car with the wheels on, but LMR sells them (including so others can see the design you’re talking about)Good info here. Thanks for sharing.
What about the rear?
Still reversed or not?
I agree that's the formula they give out for friction and that's what you'll find in a physics book from the time I went to school as well.Ahhhhhh.... but it can be described by a single simple formula: F=μη
μ = friction
F = the horizontial force to slide the object
η = the normal force (what the thing sliding weighs)
Area only comes into play with a totally different formula: F=PA
F = force to slide the object
P = the pressure the object is putting on the ground
A = the area the object has in contact with the ground
The Coefficient of Friction formula assumes ZERO wearing or abrasion of the material.
The second formula is a shear formula... it uses the area in contact as it assumes the entire surface area is going to be sheared (wearing or abrasion). This is how the "marbles" end up on the race track.
Friction doesn't cause marbles or tire wear... shearing does.
I like your thoughts and approach on this @Hack
ENGINEERING FORMULA DISCLAIMER
I did not Google and cut paste this info… it was forced into my brain in the late 80’s by relentless Ph.D’s.
man, I was expecting a 300-level dissertation and all I got was "yada, yada".And I'm sure you know static friction is different than the friction after relative motion between the surfaces begins. Yada, yada..
Static friction vs. dynamic friction… that still doesn’t change my formulas.And I'm sure you know static friction is different than the friction after relative motion between the surfaces begins. Yada, yada..
This one has my interest.I equate mu to Reynold's number
I would love to hear more info on this… I am interested in the physics.but in my head I think that mu is like Reynold's number where there really need to be curves and surfaces to describe how it changes when temperature, pressure and other things vary. It's not just a number like the formula implies.
Ha, ha!This one has my interest.
