lowatts
Ideally, what you want to do is make the spring assembly shorter (some squeeze the middle coils, others find it easier to squeeze the top or bottom coils), and once the spring assemble is shorter you will be able to tip the top of it forward away from its cradle and lift it up (thus releasing the bottom of the assemble from its cradle) and out. In other words, hold down clutch and keep it down. Squeeze the spring tight, and then tilt it forward and out. It's pretty easy once you find a way to squeeze and hold the coils. It took me some extra effort because I don't have a pair of needle nose Vise Grips. And my skinny arms don't help LOL.Could you help me make sure that I don't break the plastic elements when I remove the original spring. 1) Depress the clutch pedal by hand. 2) While clutch pedal depressed, grab the middle coils of the existing spring with a needle-nosed vise grip and tighten them together further? 3) Release the clutch pedal? If the steps above are correct, what next? Work the spring out in a particular fashion, or slide it out sideways or what? Then, once the replacement spring is in, are there tricks to reinstalling the mechanism? (I don't want to break anything like some of our brothers here have done.)
