Now that I've done a couple, I would say it takes me a half hour to install the splitter. First one took me just over an hour, as I was taking my time (and checking out all the differences + everyone wanting to talk about/check out the car too haha).How long do you guys estimate it should take a Ford tech to install it?
Sitting in the dealer's waiting room. Can't wait to see the resultsI dont see why it wouldnt
I haven't been able to figure out how to post pictures yet!You may want to check to see if the dealer used all the fasteners (screws and clips that came with it). I've found a couple instances (my own included) where they did not. I found at least one instance where they had not used the critical (IMO) "45 degree" screws.
Post up some pics if you're so inclined. If there's one thing I've learned during my GT350 experience it's Ford dealers and their service departments cannot be trusted.
You are not alone. I have 2 j-clips that need to be replaced as well. I just have not gotten over to the dealer yet. The worst part for me was the damn half moon clips. I spent 30 mins alone on one.I decided to tackle the install myself, rather than rely on a dealer tech who may be enthusiastic to work on the only GT350 that's been through the dealership, but probably wouldn't be permitted to spend several hours figuring it out. Plus, I like to be as involved with my cars as I can.
Quick question for those that installed their splitters themselves, or have really looked at one installed by a dealer: did your fastening points line up reasonably well, and have all your j-clips actually worked to properly secure the screws?
My 45 degree fastener alignment was pretty bad and required re-positioning the splitter three times, and all of the rear edge fastening points are several mm off the j-clip locations on the belly pan. And, three of the j-clips that were pre-installed on the belly pan failed.
I spent a solid three hours on this in order to avoid rushing, breaking plastic, or scratching paint, and still need to replace those j-clips so that every screw is properly fastened.
I had to widen the 45 degree openings slightly to get proper alignment. And yes the dreaded white half moon clips! Two went very easily, one went with a little difficulty, and the last one (front passenger side) took about 30-45 minutes. Used every tool in the box to squeeze that one in. It's definitely a job for someone with patience and a tolerance for fascia coolers digging into the backs of their hands for a while.You are not alone. I have 2 j-clips that need to be replaced as well. I just have not gotten over to the dealer yet. The worst part for me was the damn half moon clips. I spent 30 mins alone on one.
That's terrible to read. When it comes time for replacement please share what the cost ends up being.... The part itselfWell my splitter LOOKED fine, but in hindsight, I should have just taken it off and installed it myself. The front of it detached from the fascia at high speed and proceeded to destroy itself against the asphalt in short order.
