Vlad Soare
- Jan 21, 2020
- Bucharest, Romania
- Vlad
- 2020 Mustang GT 6MT
Hi guys,
It is time for me to replace the brake fluid in my GT, and I'm thinking of doing it myself. I've got a device that attaches to a compressor and to a bleed nipple and sucks the old fluid out.
My plan is as follows:
1. Raise the rear end of the car. Remove the rear wheels.
2. Insert the sucking tube of the device into the brake fluid reservoir and remove as much fluid as possible, but without emptying the reservoir. Leave a bit on the bottom, to avoid air entering the system.
3. Pour fresh brake fluid into the reservoir.
4. Attach the tube to the rear right bleed nipple, open the valve and start sucking the old fluid, until fresh-looking one comes out. Stop from time to time and check the reservoir to make sure it hasn't got empty. Add some more brake fluid.
5. When the brake fluid coming down the tube appears fresh, i.e. a bit lighter coloured than the one I started with, close the valve and move on to the rear left caliper. Repeat step no. 4 there.
6. Put the rear wheels back, lower the car, raise the front, remove front wheels.
7. Repeat step no. 4 with the front right caliper, then with the front left.
After each step, check the reservoir and add more brake fluid if necessary.
8. Top off the reservoir to the max line, put the cap back, job done.
My questions to you are:
- Does this look like a good plan? Did I miss anything?
- Does the ABS have any special requirements? I mean, does the fact that the car has an ABS change the above procedure in any way?
- I seem to have heard some time ago, though I'm not sure I'm remembering right, that six-piston calipers have two bleed nipples. Is that true?
- Any other tips or tricks?
Thank you.
Thank you.
