There's definitely something wrong if you're seeing that much boost. I would double check the boost control solenoid and hoses to make sure they haven't came loose or became broken.So I finally got around to returning back to stock...And who would have guessed...same exact issue. Looks almost identical, although the boost is MUCH more choppy stock. DV+ had a nice smooth line since it didn't have any issues holding boost. It's staying between 22-24 psi, but spiking up to 29 psi still. So much for how "awesome and certified" the stock BPV is. I guess the question is...Is it safe to be spiking 7 psi? I doubt an increase of 32% boost is a good thing for the life of the engine.
But that can't be right! Arghx7 says every part Ford put in the EB is amazing and it's just a design feature...There's definitely something wrong if you're seeing that much boost. I would double check the boost control solenoid and hoses to make sure they haven't came loose or became broken.
