Siege
Amsoil DCT fluid with a MGW shifter made a huge difference in smoothness and shifting for me.
That's still not what Amsoil recommends for your transmission. Calimer does recommend the 75W-90. I think a great start will be to put any brands recommended fluid into your transmission.Holy crap. I was wrong guys. I looked up my invoice and this is what I purchased. I SAID "diff" by mistake...
Manual Synchromesh Transmission Fluid 5W-30
Quart Bottles (MTFQT-EA)
Qty:2
$18.29
ADDED TO CART
Manual Transmission & Transaxle Gear Lube 75W-90
Quart Bottles (MTGQT-EA)
Qty:1
$20.19
RE-ORDER
RE-ORDER ALL
Does Amsoil even have a recommendation? For a while they did not. To be fair, any GL-4 rated trans oil is going to be fine. OE spec calls from 6-7cst@100C which is in line with most DCTF fluids. Somewhere around a straight 75W. Using something thicker isn't necessarily going to break anything or cause problems.That's still not what Amsoil recommends for your transmission. Calimer does recommend the 75W-90. I think a great start will be to put any brands recommended fluid into your transmission.
It's the 2 quarts of 5w-30 fluid that would give me concern.Does Amsoil even have a recommendation? For a while they did not. To be fair, any GL-4 rated trans oil is going to be fine. OE spec calls from 6-7cst@100C which is in line with most DCTF fluids. Somewhere around a straight 75W. Using something thicker isn't necessarily going to break anything or cause problems.
I'll swap it out and start over.That's still not what Amsoil recommends for your transmission. Calimer does recommend the 75W-90. I think a great start will be to put any brands recommended fluid into your transmission.
Oh, interesting news. Thanks for the information. I'll look into this DCT fluid you're using.https://www.amsoil.com/lookup/auto-...l-8-cyl-engine-code-f-99f-f/?volume=us-volume
Personally I've been running Motul Multi-DCTF for 60K (changed twice so far) and my MT-82 shifts like a dream down to -10 deg, F.
I'm about to join you on the dark side. If it works for the stripper, that's a huge achievement lolI've been using Motul DCTF in my MT82-D4 for about 2 years now and I beat the motherloving poop out of mine, would very highly recommend. The only reason I'm on transmission #2 is because I slam 3rd like it owes me, and the shift fork had enough of my shenanigans. When I drained the trans, it looked brand new.
I'm not even sponsored by Motul (perhaps I should) but honest, given all the crap that I put it through, the two things I can count on are the engine, and the transmission, and both of them have Motul running through them.I'm about to join you on the dark side. If it works for the stripper, that's a huge achievement lol
Pat - I'm having a Lethal LPX clutch and MGW X-Spec shifter installed next month (got the clutch - i'm waiting for the shifter). Should I dump the stock t-fluid and use the Motul?I've been using Motul DCTF in my MT82-D4 for about 2 years now and I beat the motherloving poop out of mine, would very highly recommend. The only reason I'm on transmission #2 is because I slam 3rd like it owes me, and the shift fork had enough of my shenanigans. When I removed and drained the trans, it looked brand new.
That's a good question. Is stock the Ford Motorcraft stuff in the reddish bottle? If it's still fresh/newish, perhaps let it sit for a bit while you get a feel for the clutch and shifter, trying to learn their new norms. Once you've got down that feeling of what is the "new normal," give it a flush and come see us on the trackPat - I'm having a Lethal LPX clutch and MGW X-Spec shifter installed next month (got the clutch - i'm waiting for the shifter). Should I dump the stock t-fluid and use the Motul?
