Adam's e-tune increases the boost a little more but his free tune that comes with the Cobb is around 20 psiWith the off the shelf map from Cobb I was hitting over 23 psi. With Adams tune I'm hitting 20 psi. With that said, Adams tune definitely feels stronger/faster than Cobbs even though it has less boost. He's makes power with his timing, delivery, and fueling strategy while keeping boost as safe as what it is stock. Apparently boost isn't everything, if that was the case we could all be professional tuners and just turn up the boost.
OH... can't wait to see your results... hopefully you will start a new thread.I got a great deal on the AP. I'm getting the rest of my mods installed this weekend and get my Unleashed tune revised and then get Adams tune installed on the AP, then dyno with the Unleashed tune, then Adam tuned to see which makes more power. Then the same when I get to the drag strip.
How long does it take to get the OAR to -1?To do a fair comparison, it sounds counter intuitive, but you cannot do back to back dynos. After you uninstall the unleashed and reflash with the cobb its gonna reset the OAR to 0 and leave alot of power on the table. You're gonna have to do a dyno with unleashed then load the cobb and drive around to get the OAR to -1 before doing another dyno to get a fair comparison. Stage 3 motors made this mistake. Same goes with when you're at the track.
Quite a while lol took me over an hour of cruising both city and highway.How long does it take to get the OAR to -1?
I will be able to force OAR after a reflash in about a week. Waiting on a Cobb update.
OAR is a factory table not a Cobb table. The factory tune still calculates OAR and it's to prevent knock with a poor quality fuel. There is a single table setup with mostly a single value in it that is negative. OAR reads in positive and negative and -1.00 being "100%". -1.00 x -5 = 5* of additional timing.This will be good. As long as no idiots put in 87 octane and load the 93 tune. I think Cobb did this as a safety protocol. In theory, the way they have it set up is good incase that happens. Running aggressive timing on 87 octane if the OAR is tricked into thinking its 93 is gonna equal a lot of knock. Might wanna put a big caution on enabling that feature. It's gonna be real good for dyno comparison.
