2019 GT350 Lowering Springs
tj@steeda
Timothy
Onyx,
Shoot me your contact info - our tech has done some testing with the Steeda springs & the GT350R as I believe we recently installed them at our shop.
I can help get you the answers you are looking for!
TJ
mmakam2
Houston, TX
2019 GT350
Hey do you guys change the jounce bumpers when you do the lowering springs? I am about to do the FP springs. Also I see the handling package with sway bars includes new bumpers, so not sure what to do?
Niz55
Us
17 GT350
The handling package is for the regular mustangs. You do not change your bump stops. The front have internal stops and the rear have external.
Niz55
Us
17 GT350
That's is just a generic picture. For the Shelby it does not include bump stops. Check out lmr for the right picture. P/N: M-5700-N
hiiammarcin
Alabama
2017 GT350R
Eibach springs. Work great.
On the track and a full compression load, do you rub? I read that the front is 201 lb/in vs 250 on fpps, does the front feel too soft?
Since Eibachs are the lower than rest of the bunch, how are they for daily driving? My concern is rub while turning since the spring appears bit softer.
hiiammarcin
Alabama
2017 GT350R
I am interested in the Steeda springs for my GT350R, just no reviews if they are better than the R springs. I had the FP springs on my GT350 and loved them. The Steeda springs are stiffer than the R springs. Anybody rocking the Steeda’s? I Want to do sways and springs and am leaning toward Steeda or BMR? I mainly use the car for HPDEs and street.
Same here. Looking for springs for my 17 R as well. Drop on these is 2mm more than FP, which IMO is more than welcomed. Curious what the rate is for these.
The Chairman
South TX
‘09 GT500KR & ‘16 GT350 Track Pack & ‘20 GT500 HP
No rubbing at all. I have 305-30x19 SC2’s all around.
They feel stiffer than stock, but not jarring. I can’t compare to others as I have only driven stock and Eibachs.
The combo of lowering springs and the shorter tires does mean you will scrap the front more. The shorter tires alone lower the car about 1/2”. Just be careful.
Rob-17GT350
Ohio
2023 Mach 1 HP, 2020 F350 Powerstroke
Here's mine on FP springs and OEM MPSS 295/35/19 & 305/35/19 tires
Here it is on 305/30/19 Sport Cup 2 tires all around
Do you happen to know the distance from the ground to the bottom of the splitter in front of the tires with FP springs with the OEM MPSS and the 305/30/19? I'd like to install the FP springs but I have to use 3" tall race ramps in order to get the car on my 2-post lift. Don't feel like having to use additional puzzle pieces to get the car on the lift.
Thank you!
Rob-17GT350
Ohio
Could someone with FP springs on GT350 with OE tires please measure the distance from the ground to underside of the splitter? Also someone with 305/30-19 tires? I would greatly appreciate it. Thank you!
squid678
Squid678
Edenton , NC
Joe
2019 Shelby GT 350, 2020 Explorer ST, 2018 F-150 XLT
Very interested in the measurement as well!
alan0614
Granite Falls, NC
Alan
2017 GT350 Oxford/Blue
Mine measures right at 4”. The set up on 305’s should be between 1/4” and 1/2” lower.
