2018 MT82-D4 gearing?
Nuked
Morgantown, WV
2016 Triple Yellow GTPP w/Recaros
All about MPG. With the A10 and it's better fuel economy they had little choice but to adjust the gearing for the manual. Can't afford for the manuals to skew the MPG fleet average too much.
Manuals are a dieing breed guys. Enjoy them now while they last.
UAmach1
Bullitt Hopefull
PA
Ford/INFINITI
I'm going to wait till I see full reviews, and hopefully official gearing numbers, but this is making me wonder if I should go with a 17 or GT350 instead of the PP2 now.
l'Ingegnere
Midwest
TBD
I'm quite certain my estimated ratios are correct, see for yourself if you wish.
[ame]
EFI
Masshole central
5.Br0
So basically they got rid of 3rd gear and moved everything over while also making 1st not as tall.
I like the first gear change, if it's taller indeed...but the other part sucks big time.
racingandfishing
Austin, Texas
2015 Mustang GT PP
From another thread:
Originally Posted by DickR View Post
According to someone (I forgot his name ) at Ford Performance Techline who looked up the specs this morning the MT82-D4 used in the 2018 5.0 Mustang gear ratios are:
3.24, 2.10, 1.42, 1, .81, and .62
For the PP2 that sounds like the initial post (in that other thread) guessing MPH wasn't to far off.
Assuming 3.73 rear and 26.2in tire @ 7400rpm
3.24 - 47.73MPH
2.10 - 73.64
1.42 - 108.9
1 - 154.64
.81 - 190.91
.62 - 249.41
It appears anything above 4th gear is useless for anything other than MPG.
l'Ingegnere
Midwest
TBD
PP1:
After 1st Shift: 4800 RPM. 35% RPM Drop
After 2nd Shift: 5000 RPM. 32% RPM Drop
After 3rd Shift: 5200 RPM. 30% RPM Drop
After 4th Shift: 6000 RPM. 19% RPM Drop
After 5th Shift: 5650 RPM. 23% RPM Drop
1st Gear is 50.5 MPH at 7400 RPM
2nd Gear is 77.9 MPH at 7400 RPM
3rd Gear is 115 MPH at 7400 RPM
4th Gear is 163.5 MPH at 7400 RPM
5th Gear is 201.9 MPH at 7400 RPM
6th Gear is 263.8 MPH at 7400 RPM
GT350:
After 1st Shift: 5650 RPM. 31.4% RPM Drop
After 2nd Shift: 5950 RPM. 27.8% RPM Drop
After 3rd Shift: 6350 RPM. 23% RPM Drop
After 4th Shift: 6650 RPM. 19.4% RPM Drop
After 5th Shift: 5200 RPM. 37% RPM Drop
1st Gear is 55.5 MPH at 8250 RPM
2nd Gear is 80.9 MPH at 8250 RPM
3rd Gear is 112 MPH at 8250 RPM
4th Gear is 145.5 MPH at 8250 RPM
5th Gear is 180.4 MPH at 8250 RPM
6th Gear is 286.3 MPH at 8250 RPM
Angry50
Jacksonville, FL
Fred
2017 Shelby GT350
i know some manual swap were done with longer gears and they just lowered rear gear to compensate. I have heard many time the 3.73 with mt82 and boost is too much. did anyone here about strength upgrades?
racingandfishing
Austin, Texas
2015 Mustang GT PP
I haven't seen anything about strength. Besides gear ratios, just this:
"Responding to customer criticism about shifts sometimes being hard to execute, Ford has also taken the liberty of changing out the MT82-D4’s synchromesh rings, revising the cone angles and tooth geometry to help slide into gears a bit easier."
Read more: http://fordauthority.com/2017/11/th...n-is-new-and-improved-for-2018/#ixzz4yWgDv1q7
UAmach1
Bullitt Hopefull
PA
Ford/INFINITI
This is from a post in another thread, not ure if it helps any:
3.24 - 47.73MPH
2.10 - 73.64
1.42 - 108.9
1 - 154.64
.81 - 190.91
.62 - 249.41
UAmach1
Bullitt Hopefull
PA
Ford/INFINITI
1-4 this is almost identical to my 5 speed Mach 1 so I should feel right at home.
Loved ripping though gears with the 4.10 I had, and your right they look like the 3650 but +0.1 for 1-3, 4th is identical and 6th is almost he same as the 3650 5th.
HISSMAN
Large Member
West Virginia
2016 Oxford White GT/PP Premium
Eh...
UAmach1
Bullitt Hopefull
PA
Ford/INFINITI
That might be the thing to do with this one. Would that make 1st way too short though?
Probably not, I know some guys would run 4.30's. and 4.56's
UAmach1
Bullitt Hopefull
PA
Ford/INFINITI
Mach 1 gears were 3.38, 2.0, 1.32, 1.0, .62. I look forward to the double over drive. When cruisng between 45-60mph 4th was to short and 5th was to tall. I'm actually thinking when the stock sc2's wear out (which will be fast) ill do the slightly taller 305/35/19 tire.
Sounds like a good plan. I really enjoyed the Mach1's gearing.
