2018 MT82-D4 gearing?
Angry50
Jacksonville, FL
Fred
2017 Shelby GT350
cheap swap for boosted cars? if it is stronger with friendlier gearing?
Cardude99
Phoenix, AZ
Sam
2018 Ecoboost
Ok so this news sort of sucks. Maybe I will have to be a convert and pick up an auto. Just want to see reviews, tests and what the PP2 ends up being.
stang17
Wilkes Barre, PA
2017 GT Premium PP
I wonder if the 15-17s transmissions crap out durring warranty period, if you would be able to have Ford replace it with the 18 transmission.
cpelaez1
Silver Spring, MD
Cristian
2016 Shadow Black 5.0 Vert
I know for me personally since Im boosted this transmission would be much better for me. I myself may switch from 3.73 to 3.31 because Im literally flying through the gears so fast I really wish it was a bit longer. Maybe an 18' transmission is the way to go instead and keep the 3.73
Angry50
Jacksonville, FL
Fred
2017 Shelby GT350
this is my thought. i have 3.55 gears and 1st and 2nd go so fast and im on a base phase 1 roush. i imagine once you get to 700+whp that becomes a shorter time span. not to mention you just blow the wheels off below 3rd gear on the street.
cpelaez1
Silver Spring, MD
Cristian
Yea man Im on 3.73 and 1-3 gear are barely usable tbh. 4th seems to be the sweet spot but I would like to use 3rd gear more lol.
Angry50
Jacksonville, FL
Fred
2017 Shelby GT350
is it possible to get the internal gears themselves and just modify your current mt82?
GT Pony
Pacific NW
Sucks that the new MT82-D4 now has 4th gear as the 1:1 ratio. In the 15~17 manual, I liked that 5th was 1:1 which made it a close ratio 5-speed with one OD gear (6th) for gas mileage on the highway.
EFI
Masshole central
5.Br0
It's a tossup, but most likely not. The only time they would ever give you an 18 trans is if the 17MY unit is no longer made and they have absolutely 0 stock of it anywhere. But even then, they most likely would give you a reman one and it would be a tossup if it's a 17 or 18 MY unit.
If you're friendly with the dealer and the service department, you might be able to sway them into giving you a new 18+ unit, but it's at their discretion.
HISSMAN
Large Member
West Virginia
2016 Oxford White GT/PP Premium
How does this alter the manual dyno numbers we have seen thus far? Haven't they been running the manual '18's in 5th?
Barrel
Hoonigan
Cars and Trucks
Dyno would correct for the trans gearing. But unnecessary - they'll just dyno in 4th.
HISSMAN
Large Member
West Virginia
Depends on the dyno. Also, most of them were dynoing in 5th and not able to get a full run.
whatsup62
Jupiter
15-17 MT82 boosted guys - if you you keep the MT82 go with 3.31 rear.
I broke two MT82 and went TR6060 (which is heaven) then went to a 4.09 rear...what a combo. This is how Ford should have built them.
UAmach1
Bullitt Hopefull
PA
Ford/INFINITI
What made Ford change from 4.10 to 4.09 I missed when this happened.
whatsup62
Jupiter
I think it is actually 4.10...I think it's a marketing thing. US gear sold them for a while as 4.10's then FRPP came out and called them 4.09's (made by US Gear).
