wildcatgoal
@sirboom_photography
Did anyone post P/N for pigtails here yet? Went through the whole thread, couldn't find.
its installed had to rig some vac lines that I'm fixing today and deleting the imrc ill post pics and vac line specs later on today
That's the evap system. When you take the screws out you'll see you can stick what I believe should be a 1/2" ID hose on it and then in to the manifold.I'm gearing up to install my 2018 manifold this weekend and think I have it mostly figured out. A big thank you to everyone that uploaded pics & the IMRC pinout info.
Wiring the pigtails seems pretty straight forward, and I think I can figure out adapting the vaccum lines on the front of the manifold but I still have a question:
What's the sensor on the front of the 17 manifold? There's no provision for it on the 18? What needs to be done? Leave it unplugged or does it need to be swapped over somehow?
Here's a pic of what I'm talking about on the 17 manifold:
I ported the runners and TB opening on my 18 manifold, including port matching the GT350 TB adapter to the intake. I also have a Pmas no tune GT350 intake on order to replace the GT350 intake that came with the PP2. Hoping this setup will make some POWER!
So 1/2 ID for the evap and 3/8 for the rest?That's the evap system. When you take the screws out you'll see you can stick what I believe should be a 1/2" ID hose on it and then in to the manifold.
I still haven't done my install yet as I have 12 gallons of E85 to run though.
Patiently waiting for this information... Thank you!its installed had to rig some vac lines that I'm fixing today and deleting the imrc ill post pics and vac line specs later on today
Very cool, thanks DarkestHour! I owe you a beer.That's the evap system. When you take the screws out you'll see you can stick what I believe should be a 1/2" ID hose on it and then in to the manifold.
Cool thanks, my ford mechanic buddy told me the same thing. Learn something new everyday!Normally connector pin outs are viewed from the pin side not the wire side.
