Schuvwj
Not long!What's the life expectancy of this motor?
what time is it?What's the life expectancy of this motor?
It's tree fiddy.what time is it?
You can thank that TH400 for the stunning visuals.I was NOT expecting the front end to jump like that lol.
partially responsible for Earth's rotation.I think we call that TORQUE!! lol
What does your motor refresh consist of? What gets replaced exactly? How many passes are you making a season to require yearly refresh? Just trying to make sense of things. Your power level sounds too costly, cost prohibitive to maintain. If the engine is rated for certain power, why would it need that much of a constant refresh?Yes it was the last before deciding to switch to twins. A motor like this prob should be fresher up after every season. I will be the first to tell you it’s hard on parts and is only as good as the weakest part, because when you push them this hard, they will break. Stay on top of maintenance. It is key.
All good questions. To be honest I dont keep track of passes to refresh. I do it whenever the oportunity allows in the off season about November. Maintenance is anything from bearings and rings. They do a complete teardown and check everything out. You are correct, it isn't cheap at that HP level. There are a lot of things that people don't tell you that you find yourself having to improve upon.What does your motor refresh consist of? What gets replaced exactly? How many passes are you making a season to require yearly refresh? Just trying to make sense of things. Your power level sounds too costly, cost prohibitive to maintain. If the engine is rated for certain power, why would it need that much of a constant refresh?
Also, how do you like you stand alone ECU compared to stock ECU?
I've always been a fan of this car
That pretty much sums it up. Don't forget that badass JPC spec, ProTorque converter!All good questions. To be honest I dont keep track of passes to refresh. I do it whenever the oportunity allows in the off season about November. Maintenance is anything from bearings and rings. They do a complete teardown and check everything out. You are correct, it isn't cheap at that HP level. There are a lot of things that people don't tell you that you find yourself having to improve upon.
This last season I broke the sleeve in the #6 cylinder. Come to find out there were several factors that caused that and I don't want to get into all that. Long story short, I made a decision to change from a PD blower to turbo's. TKM resleeved the Bear Block and machined it correctly for the sleeves (as it was off from Bear). This also wasn't cheap. Justin, Mike and Eric Holliday (who tunes the car) had been working with me and wanted me to go with turbo/turbo's and shoot for some BIG power. They have some of the fastest mustangs in the country. They built me a new combo, changing a lot of the combination. New custom CP pistons, the rods are Callies Ultra billet rods, the previous 3.8 stroked billet Winberg crank, RGR timing chain kits, MHS custom TBX turbo cams and so much more. None of this is cheap either! LOL
The aftermarke ECU- AEM is amazing! This allowed us to control the power of the PD blower hit and make it down the track. I believe this is a huge part of the build and will be even more crucial for the next combo. I love it.
I have a Frankestien Billet intake, 2600lb injectors and two Precision Turbos 72/75's with billet wheels and ball bearings. The TH400 was freshened up and some new billet parts and dump valves so if we want to spool those turbos extremely quick or use them to assist in getting down the track.
I know this is a little more indepth than you probably wanted, but I did this let people know more about the build and what it takes at the 1500whp and not shooting for 1800-2000hp level. It isn't for the faint of heart. It is extremely expensive! The money is just the tip of the iceburg. The time I put into the build, labor and the planning, people will never see. I have a lot of good people that help me also. Friends like @80FoxCoupe that spend days in the garage.
I also have businsess that support and help, without a good Team, this would not happen.
Thanks for the detailed answer. I can somewhat relate but I am not even remotely on your power level. I remember sitting down one time, adding up parts cost and labor costs that I had spent and I realized that I could have picked up another brand new latest premium GT with extra money in my pocket and the worst part was that I didn't have the car back at the time. I was very frustrated with the whole build process, you have to plan things very well, I've always believed that the chasis and suspension setup/build should dictate the power level to a large extent so I tried to focus on that. It's not easy. So when you mentioned needing engine refreshes, my mind was a little blown, because I can't imagine frequently having to do that and I was curious the data you were basing that decision on. Props to you. You're also in a unique situation where you're your own experiment, you're doing things no one has done before so your car is the R and D, can't save money on mistakes by seeing what has worked and hasn't.All good questions. To be honest I dont keep track of passes to refresh. I do it whenever the oportunity allows in the off season about November. Maintenance is anything from bearings and rings. They do a complete teardown and check everything out. You are correct, it isn't cheap at that HP level. There are a lot of things that people don't tell you that you find yourself having to improve upon.
This last season I broke the sleeve in the #6 cylinder. Come to find out there were several factors that caused that and I don't want to get into all that. Long story short, I made a decision to change from a PD blower to turbo's. TKM resleeved the Bear Block and machined it correctly for the sleeves (as it was off from Bear). This also wasn't cheap. Justin, Mike and Eric Holliday (who tunes the car) of JPC Racing had been working with me and wanted me to go with turbo/turbo's and shoot for some BIG power. They have some of the fastest mustangs in the country. They built me a new combo, changing a lot of the combination. New custom CP pistons, the rods are Callies Ultra billet rods, the previous 3.8 stroked billet Winberg crank, RGR timing chain kits, MHS custom TBX turbo cams and so much more. None of this is cheap either! LOL
I know this is a little more indepth than you probably wanted, but I did this let people know more about the build and what it takes at the 1500whp and now shooting for 1800-2000hp level. It isn't for the faint of heart. It is extremely expensive! The money is just the tip of the iceburg. The time I put into the build, labor and the planning, people will never see. I have a lot of good people that help me also. Friends like @80FoxCoupe that spend days in the garage.
Fantastic car!!!
