Furore
- Feb 5, 2016
- Honolulu, HI
- 2015 Mustang GT Premium 6A
I have a similar setup with the 3.7 pulley, and I make over 721hp on the dyno...
yes this turn that off. Also do you have the updated tune?Your problem is you have the MAX rpm set to on! Turn it off.. Whipple is working on a revision current. It does not work on the track or street your shift points will be way off and you will make less power due to it. I have the same setup and the moment i turned the max rpm off the car went 10.7 @ 134.
Saw that and though the same. When I click to edit and change it to 3.15 , it reads 3.15 without editing. If I go out of the field it reads 3.31 as in the picture .Just something I noticed, but you said you are running 3.15 gears, but the Flight control shows 3.30.....
If that is off, could be a major hiccup.
I haven't tried on my 2015 but in the 2013 the response was so slowww that either I short shifted or hit the rev limiter.I have shifting issues with the Whipple tune on my car. I picked up 3 tenths and several mph by shifting the car myself. What's you mph in the 1/8? What was the DA on those runs? Do you have a boost gauge to make sure you are at 11psi?
The response is pretty good in mine. It's not a DCT so you do have to learn the timing a bit. I hit the rev limiter on my 1-2 shift at the track because 1st gear goes by in the blink of an eye. It just takes some getting used to. Unless they can fix it, I'll be going custom tune next year.I haven't tried on my 2015 but in the 2013 the response was so slowww that either I short shifted or hit the rev limiter.
Did you have any issues with the paddle shifter response?
I have 3.15 gears and my flight control also shows 3.30. Wondering if this is happening to everyone with 3.15 gears????Just something I noticed, but you said you are running 3.15 gears, but the Flight control shows 3.30.....
Same here. @whipplesc any input on this?same here. It changes back to 3.30 if I edit it.
