In our constant quest to push the performance limitations of our vehicles both off and on the track, it is easy to forget that sometimes the most important modifications you can make are the ones that improve driver performance and increase safety if things get hairy during spirited driving.
The Brey-Krause Safety System for the S550 Mustang was created with the focus of locating the driver in the car and reinforcing the structure around the driver. One component of the complete system is the company’s R-1180 S550 Mustang Harness Mount Bar.
The Harness Mount Bar properly locates and supports racing shoulder harnesses relative to the driver and in the case of an accident, helps to protect the driver’s shoulders and spine. It has also benefits to the driver that extend beyond the catastrophic, as the harness guides prevent excessive shifting and fatigue of the driver during the high G-loads of cornering and braking.
Of course any safety system needs to be functional and easy to install for it to be widely adopted. The Brey-Krause safety system does not disappoint in this department as the harness mount bar allows for the use of 4, 5, or 6-point harnesses as well as the use of the factory 3-point seat belt. It’s also easy to install and remove and retains the functionality of the back seat when not installed.
See the Brey-Krause S550 Mustang Harness Mount Bar and their complete safety system in the forums.
