XXR 521 20x10.5 square - the hunt for stance
stewman01
SHAW AFB SC/Columbia SC
2015 Mustang GT 50 Year Performance Package
Hey guys trying to get a drag radials in the rear will a 275/40/20 nitto 555r fit without rubbing.or hitting the quarter panel? I put a 295/35/20 michilin Pilot super sport in the rear but I think it’s gonna rub when I hit a pothole. Trying to get something with grip as I am supercharged.
Thanks
Wouldnt know without test fitting but will probably be good in the rear. Are u running stock springs? If so I would bet you are good for play in the rear
Edyuly
Paxton supercharged
Easton pa
2015 mustang gt
Hope someone can help. I have these wheels on eibach springs on the rear I milled 5mm off the center to properly fit my 295/35/20 michilin pilot super sport my question is will I be able to fit a275/40/20 nitto 555r without rubbing Due to taking 5mm off?. Really would like to know before purchasing the tires to find out they won’t fit.
Thanks in advance
wildcatgoal
@sirboom_photography
TBD
Need to know original offset of the wheel to answer that 100% confidently, but a less-wide tire should not have an issue if a wider tire doesn't. The height of the tire on a 20" is a lot... that's what I'd be worried about.
Edyuly
Paxton supercharged
Easton pa
2015 mustang gt
20x10.5 with a 30 offset milled down 5mm . The tire height is 28.8
wildcatgoal
TBD
So then it's now technically a 35 offset wheel - is my math going in the right direction?
Again, your issue is mostly tire diameter, not width, if a 295 will fit.
Also, if you really want the best drag times, you want 0 camber (ideally somewhere between curb weight and squat, more or less) so if you have a bunch of rear camber now, and take that out, you may introduce an issue. Keep this in mind.
DeepakGTCS
Vancouver
2016 J7 California Special
Feast your eyes on this bad bitch! Damn im in love with this thing! I might do 5mm spacers on the rear lol man i love it!!
Did you get extended studs?
noidea79
Perth
Mustang Ecoboost
Bump up for this thread. Anyone have these rims on the Ecoboost ? Do we still need spacer for Ecoboost ?
fordguys550
yep..."just" a V6
tehachapi, ca
2016 v6 6spd
Only if you have a pp. Base brakes dont require a spacer
Cburr4
2017 Mustang GT with Performance Pack
Thank you guys for the info. Ever since i saw the OP on YouTube with these wheels, I had to have them!
JuRuKi
SoCaL
2016 GT/PP
beautiful! what are you dropped on and what size tires?
Ronin_5.0
Cristian
So for a 2016 non PP, what front sized spacer would be required? I've seen people say 5mm front spacer, and some have said, non PP GT's dont require a spacer at all.
