WILL THE PP2 WHEELS WORK ON THE GT PP
tonyd1
US NAVY,US ARMY,USCG-RET
New Port Richey,fl.
Tony
2018 Mustang GT Ruby Red PP,Automatic
Anybody know the answer to this question. the offets are-45-pp, 40-pp2 fronts and the rears are the same 52.5. I really like the Pp2 wheels-Tony
DickR
Raleigh
The PP2 wheel info in the order quide is 9.5" vs the PP 9".
0.5" wider means 0.25" or 6.35 mm wider on each side of the center line. The offset change per the info you found is "only" 5 mm so "all else being equal" there will be 1.35 mm less clearance . . . if I did the math correctly.;)
What we don't know yet is whether there are other changes which increase or decrease clearance. Both between the 15 - 17 and the 18 and between the 18 GT PP and the 18 GT PP2. Also, what size tires?
Question: Never mind. I read your other thread on PP2 wheels and they aren't OEM PP2 as far as we know. I assume Ford hasn't published the actual PP2 wheel offset.
tonyd1
tonyd1
New Port Richey,fl.
Tony
according from the guy at MIDWEST WHEEL AND TIRE, they are the OEM pp2 wheels. I went on one of those RIM AND TIRE caculator things , put the numbers in that we're give me and the tires I wanted and it looks like they will work fine with 275's up front and 305's in the rear. I wanted to get aspect size of 40 front and rear but having a hard time finding a tire that size in the rear-Tony
Grintch
Hunstville
2015 GT PP
So how does he have OEM PP2 wheels when no PP2's have been made yet?
tonyd1
tonyd1
New Port Richey,fl.
Tony
well, I guess they made at least one set because he's got it:D
