Why You Can't Skip This Step When Working on Suspension!
tj@steeda
Timothy
Whenever you're installing a part underneath your car, you typically lift the car up, remove the wheels, loosen the necessary parts, install the new one, then tighten everything back down, and then lower the car back down. However, on certain components on S550s and S650s and many other vehicles, the bushings are physically bonded to the sleeve, preventing movement. If you want your suspension to be riding properly and at the correct ride height, then you can't skip out on this step when working on your suspension.
