Inthehighdesert
This is just a heads up for anybody doing an install on a 350. My car threw codes P0205, 206, 207, after about 150 miles. Started having a miss, Turned out the factory injector harness for cylinders 5-7 was not completely connected from the factory. I'm referring to the actual wiring inside the loom going to the injectors. The car never had an issue before the install and the movement during the install moved it around just enough to cause the issue. It was a simple fix of resoldering the wires together.
