Angrey
- Jun 21, 2020
- Coral Gables
- 2016 GT350
Got the heavy lifting done this afternoon/tonight.
Car made 1082 and 863 on 19 lbs of boost and 21 degrees max timing (very very end). Shorting the redline at 8k.
Made 1045 and 857 on 19 degrees. (only 8k redline) So the car is still picking up good power/degree and loving what we throw at it, so we could run timing out more but sticking to my "overdesign and underutilize" philosophy, I asked to stop there and just start cleaning up some issues with the tip in/initial hit and cleaning up some of the curve.
IAT's were awesome with coolant at 170. Last run ended at 106F and the run prior was 99F (92 ambient). What's weird is the IAT's would spike and then drop back down (getting the flow across the intercooler).
The major item I wanted to fully test was the fuel system.
We're ironing out some whipple/PD blower related issues on the hit. I'm getting ready to finalize my fuel system thread where I walk through the entire setup. On initial throttle, the boost jumps to 16 psi in a traffic jam, then the motor rushes to catch up so boost dips slightly, then rises to 19 lbs and never catches the motor again (through 8k).
The problem we're seeing is that A/F drops to low 11s, then rises slightly to mid 12's between 3-4k then drops back to low 11's again. The sudden on rush of boost is spiking the regulator, the regulator is then allowing a rush of fuel in increased pressure, the return side sensor is seeing a spike so the pumps are momentarily pausing and then they quickly catch up and the A/F is smooth from there out. It's not a huge issue that low in the rpm range, but something we're working on smoothing out. Otherwise, the brushless DW's and Fuelab Electronic regulator are working as I'd hoped. They go to low speed on idle and they only spin up when the regulators senses a drop in return flow. Very efficient. When cruising I'm drawing approximately 16 amps between the two of them. I currently have no siphon system but am lifting fuel from the passenger side with a pair of DW low pressure lift pumps that each draw about 3.5 amps. So in total at idle and low load, the entire system is drawing about 23 amps. At 75 psi (55 base pressure + 20 lbs of boost index) the system is capable of supporting over 1200 to the wheels on E85.
For comparison, a single TI 285 draws about 18.5 amps at idle pressure (55 psi) and flows roughly the same as the DW440, but loses 40 lph or more to the syphon system.
All in all a very encouraging and sigh of relief test session for the entire setup, but also the fuel system and temps were great too. I'm pretty happy. Hopefully have final dial in and reports Monday or Tuesday.
