Whipple(*edit: all FI) CHT temps and Thermostats
sigintel
Ray
2018 GT
Running non PP rad.
Anyone have problems with the Motorad 160F tstat?
Heard the EvenFlo 160F was junk.
Having doubts about the Motorad 160F I am running.
Heard the $20 Duralast Autozone 160F works but it *might* be a Motorad mfg version so wtf?
Maybe I got a bunk tstat or expecting 160-190 CHT is not realistic on a 160F marked tstat because of its flow/pressure profile (needs higher idle pump volume or RPM)?
stock OEM tstat: 195-205 highway, 220 idle after hard driving
Whipple w Motorad 160F marked tstat: 200 highway 225 idle after hard driving
Edit:
Reische 160 ordered from Lethal
PP rad ordered from Levitown
sonic
NY
Prius
I bought the 170 for my Whipple
Evo_Rob
Mmm... Boost...
Virginia Beach
Rob
160's are junk. get the Reische 170
RipShift2015
Katy, Texas
Nate
2015 GT PP
My head temps were running 215 to 225 all the time after I added Procharger. Now, running the Reische 170, it stays at 185-192.That's cooler than it was stock.
Barrel
Hoonigan
Cars and Trucks
I'm at a constant 205-ish with the stock tstat :shrug:
sonic
NY
Prius
I think the 160 flows to fast and doesn't allow for enough heat to dissipate which is why the 170 seems to perform better.
Dat Boi Kumar
Rosharon,Tx
Chad
2015 Comp Orange Mustang GT
I swapped out the motorad for the reische and definatly saw a difference in temps.
Roh92cp
Fort Kent Maine
Shawn
OW GTPP Whipple
I just changed the Whipple 160 for the Reische 170 and found it interesting that the Reische direction contradict Whipple. Whipple calls for 2 bottles of water wetter in the engine coolant and Reische directions says not to use water wetter in coolant concentrate higher than 40% antifreeze or precipitants may occur.
zaquhree
Orlando
2015 S550 GT
I see 190 cruising and 197-200 after ripping on it
sigintel
sigintel
Ray
2018 GT
Flow rate curve
Increased flow rate is good.
The 160 flow is actually low per degrees over 160.
In otherwords, the damn thing aint opening as much per increase in temp.
The 170 has a much steeper flow rate increase curve per degree Ftemp increase.
If you have any doubts, just take the tstat out like I did.
Works great but you are going to foul plugs and the cold temps dont vaporize fuel as well so it actually runs a little leaner although tune is trying to compensate.
Would need a fuel rail heater to run no tstat and then the oil pump parasitic is higher pushing cold/thicker oil.
jwhite
jwhite
Indiana
J. Brad
15 Gt PP Roush SC'ed/16 GT 350 TrackPack 1970 Mach1
I have the Reische 160 with the Roush and all good. According to the instructions, Reische says the temp is controlled by head temp not actual water temp. You will have a 10/15 temp difference between thermostat and water temp. So if running a 160' you are around 170/185 water.
