Wheel hop shouldn't be an issue in the 3rd gear and higher where you'll be spending virtually all of your time. There is nothing to be gained (and something to lose . . . in the way you'd be presenting yourself to the other drivers there) by wheelhopping your way down the hot pit lane in 1st and maybe 2nd as you take your out lap.
But you might come by some improvements in handling precision/composure by way of the same modifications that work to reduce/eliminate wheel hop for the straight line guys.
Norm
This was exactly my thought. So I am looking at the subframe braces as a cheap solution would that be enough? I know it adds weight and doesnt do anything for the soft stock bushings. Should I just pay the few dollars extra for stiffer bushings?There isn't wheel hop per say but there is a bounce that the soft bushings of the IRS has on corner exit when putting down power. Easy fix is the BMR CB005.
