What can we do for You?
DarkHorse5.0
Project White Label
SF Bay Area
Bryn
Whippled 2015 GT PP
LevittownFordParts
LevittownFordParts
Worldwide
Benny & Mitch
S550's!
DarkHorse5.0
Project White Label
SF Bay Area
Bryn
Whippled 2015 GT PP
Appreciate the help!
AlphaCoyote
Austin, TX
2015 Mustang GT w/ PP, 2018 Honda Accord 1.5 Sport
Hi Benny,
How much for a driveshaft?
2015 Mustang GT w/ Performance Pack
LevittownFordParts
LevittownFordParts
Worldwide
Benny & Mitch
S550's!
flyinghunter
South
GT Premium
Hi,
FP is phasing these out but we have a few left here https://www.levittownfordparts.com/ford-performance-mustang-strut-tower-brace-p-3030.html
Thanks,
Benny
Just tried to order...appears that you now longer have the tower strut braces that say "Ford Racing" vs the common "Ford Performance". Dang - I was too slow to place my "Ford Racing" strut order. Can you verify that you no longer have any in stock? If you do happen to have one, I'll purchase immediately. Thanks!
LevittownFordParts
LevittownFordParts
Worldwide
Benny & Mitch
S550's!
I am sorry but they are all gone
-Benny
dguzzi
Michigan
'16 V6 w/051A Met. Guard w/foundry wheels
Trying to find the console part for the shifter. The piece that is under the chrome trim. On an automatic car it has the PNRDS piece. I need one for a standard trans. Thank you!!
TigerFire13
Athens, AL
2016 Ecoboost Premium PP in Deep Impact Blue
Looking for 2 front hub to spindle nuts, and 2 rear hub to axle nuts. I will be pulling front hubs for ARP wheel stud install, and the rears for IRS upgrades. I think the part # for the front is FR3Z-3B477-B? VIN is 1FA6P8TH7G5235410.
Thank you
LevittownFordParts
LevittownFordParts
Worldwide
Benny & Mitch
S550's!
I believe this to be part of the shifter assembly (YELLOW SQUARE) which comes with the trim plate and knob. In order for me to quote you I will need your VIN please
-Benny
LevittownFordParts
LevittownFordParts
Worldwide
Benny & Mitch
S550's!
Thank you
Hello,
Your front nuts can be found here https://parts.levittownfordparts.com/oem-parts/ford-axle-nut-fr3z3b477b
And your rear nuts here https://parts.levittownfordparts.com/oem-parts/ford-retainer-ccpz3b477g
I will send you a code you can use but with the low costs of the parts the savings will be minimal.
-Benny
dguzzi
Michigan
I'm retro-fitting the trim piece...my vin won't help. Lets assume I have a '17 base mustang with a standard shift trans. Should be the same for any engine?
LevittownFordParts
LevittownFordParts
Worldwide
Benny & Mitch
S550's!
dguzzi
Michigan
Not sure you understand, the trim not the shifter. I need to delete the prnds piece.
TigerFire13
Athens, AL
dguzzi, are you wanting to essentially use the shift boot and trim ring of a manual shifter, and mate that up to the automatic shifter you have? If so, you may have to either cut the boot, or separate the trim ring, as the trim portion is two halves pressed together, plastic welded, sandwiching the boot in between. Am I close? or am I missing your intention?
