Weird High-Pitched Sound When Turning (passenger side)
rcwilli7
North Carolina
2019 Mustang GT
So I randomly started having a really weird occurrence… I get this weird high-pitched grinding/squeaking noise when I turn but it is ONLY when it is about 45ish or so degrees — any more or any less there is no noise. It also is not the whole time at the angle through the corner — it’s only a second or so. I have taken the wheel off to see if I could see anything touching, even rotating the wheel to see if anything is touching. Possible bad bearing? Just it’ll happen at a specific angle and not at others.
Johnny Rockit
Massachusetts
Johnny
2022 Mustang GT 6-speed. 2015 F-250XLT,73 Torino
I would suspect bearings if the brakes are fine. Just throwing it out there. Assuming these are sealed bearings and replaced as a unit. Replace in pairs. If one is bad, the other is not far behind.
Any scuffing on the tire or rim?
rcwilli7
rcwilli7
North Carolina
2019 Mustang GT
Nope no scuffing when I took them off. It almost sounds like worn brakes when you come to a stop but it is only for a second.
Johnny Rockit
Massachusetts
Johnny
Is it when braking in the turn or every time you turn with or with brakes? Mileage?
rcwilli7
rcwilli7
North Carolina
2019 Mustang GT
It was happening regardless of braking. I waited to reply, because I was replacing my pads, and the noise completely went away. Not sure if some hardware had un-seated somehow but it's gone!
